LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   LT1-LT4 Modifications (https://ls1tech.com/forums/lt1-lt4-modifications-31/)
-   -   3.73's to 4.10's (https://ls1tech.com/forums/lt1-lt4-modifications/1017410-3-73s-4-10s.html)
TravisMcGill2000 Nov 12, 2008 04:59 PM
3.73's to 4.10's
i had 3.73s in my car until the last run at the track. it eat the teeth off the pinoin lol. i debaitin on going to 4.10s cause i came across some cheap. im trying to save for a 9in. my car hardly ever sees 1/4 mile tracks mainly 1/8. wat do u guys thinks should i stay with 3.73s or go with the 4.10s. car dont get very many highway miles.
xx_ED_xx Nov 12, 2008 05:03 PM
Do it!
TravisMcGill2000 Nov 12, 2008 05:18 PM
you think it will help much
StealthFormula Nov 12, 2008 05:20 PM
Make sure the car won't go into 4th with the 4.10's before you get them otherwise it will only be slower and you will need some taller tires for it to work.
TravisMcGill2000 Nov 12, 2008 05:30 PM
u mean over drive
jarretthise Nov 12, 2008 05:33 PM
no third....overdrive is 4th
TravisMcGill2000 Nov 12, 2008 05:33 PM
wat u mean by not going in to 3rd
StealthFormula Nov 12, 2008 05:33 PM
Originally Posted by TravisMcGill2000 (Post 10470348)
u mean over drive
whoops typo I meant 4th.
TravisMcGill2000 Nov 12, 2008 05:36 PM
sorry i read it wrong the car goes across the 1/8th at like 5300 rpms
BADHAWK51 Nov 12, 2008 06:42 PM
Guys that run 1/8 mile usually run more gear. I would do it you could probably run 456's if you wanted.:D
LS1 SPEED Nov 13, 2008 02:43 AM
yes..agreed
where did the car trap rpm wise with spray and the 3.73? This is important before making your choice, though running 1/8 there should be 0 issues.
I am planning to go from a 3.73 to 4.10 in my combo here soon.
blackz6sp Nov 13, 2008 07:21 AM
Originally Posted by LS1 SPEED (Post 10473305)
yes..agreed
X3
Again most of you guys have heads and cam setup, he doesnt so won't be turnin as much rpm. I was out of rpm in 1/4 with 3.73's, 150shot, and a 26" tire with stock heads and cam.
I know you said it was mostly 1/8mile but I think you'd really be screwed if you ran 1/4.
LS1 SPEED Nov 13, 2008 08:34 AM
Originally Posted by blackz6sp (Post 10473595)
X3
I will have to agree with you and was what I was getting at.
TravisMcGill2000 Nov 13, 2008 10:22 AM
k guys thanks alot.i will probly go ahead with the 4.10s. just because i came across a good deal. i plain on goin with a 9 in next spring. i will go bak to 3.73s then.
© 2026 MH Sub I, LLC dba Internet Brands
