LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   LT1-LT4 Modifications (https://ls1tech.com/forums/lt1-lt4-modifications-31/)
-   -   Hot cam and 1.6's, what pushrods? (https://ls1tech.com/forums/lt1-lt4-modifications/1021958-hot-cam-1-6s-what-pushrods.html)
2XR95Z28 Nov 21, 2008 03:00 PM
LIke the title says, i'm doin the hot cam and 1.6 rockers, what pushrods should i use? i noticed the hot cam doesnt come with pushrods? i heard trickflow has a good cheap hardend set? what should i use stock or anyone have a part number for good hardend pushrods that wont cost me a ton.
Thanks in advance
WonBadLT1 Nov 21, 2008 03:08 PM
I beleive the length is 7.200". You can check ebay for some deals, they usually have some good prices on that stuff. check out Comp 7940-16 and 7608-16.
Elliott's94Z Nov 21, 2008 03:12 PM
Are you changing the lifters as well? Best way to determine pushrod length is to get a tool that measures so you can get the correct size. As far as pushrods go, I would def go with the Trickflows.
2XR95Z28 Nov 21, 2008 03:19 PM
I'm not sure on the lifters, i heard i didnt have to, they only have 38k on them. What do you think on the lifters?
Elliott's94Z Nov 21, 2008 03:23 PM
Anytime I change stuff out I always like to put fresh stuff back in. That's just me though. The LS7 lifters would be a good upgrade and they are fairly inexpensive too. $110-125 dollar range.
2XR95Z28 Nov 21, 2008 03:30 PM
Alright well depending on how much money i got left i may pick up a set of ls7's. Anyone got some part numbers on the trickflow pushrods? summit please.
Elliott's94Z Nov 21, 2008 03:35 PM
TRICKFLOW #'s through Summit
21407100: 7.100
21407150: 7.150
21407200: 7.200
21407250: 7.250
2XR95Z28 Nov 21, 2008 03:46 PM
Awesome thanks alot!
Elliott's94Z Nov 21, 2008 03:56 PM
YUP YUP!! Good luck with the swap!
© 2026 MH Sub I, LLC dba Internet Brands
