LT1 won't start..HELP!!! I parked my trans am in my driveway a few days ago and didnt start it for 3 days, when I went to go start it, it wouldn't fire. I ran a scan on it and i got this code "Ignition System Problem elec spark timing (EST) open circuit" I checked all my plugs and everything is plugged in. I am not sure what else I can do. |
Opti probably took a dump.. |
Originally Posted by the_merv
(Post 10539808)
I really not hope, Its a brand new GM opti with only 273 miles on it |
There's a little wire that plugs into the top of the Opti. Make sure that is securely plugged in. I know mine wasn't when I replaced it and ti would sit there and crank all day. |
The plug coming from the wiring harness? |
Yea, it goes into the top of the Opti. |
I pushed on it and its on there pretty good |
I would question the warranty on your Opti and go from there. I don't know what else could be holding it up. Are you getting fuel? List of mods? edit- did you reset the battery? (to reset the code) |
Ported heads/intake custom cam 30lb SVO injectors 1.6rr LT's 52mm TB CAI MSD coil GM opti electric water pump and I'm definately getting fuel |
Is everything connected near the Coil, make sure nothing come un-plugged.. |
yea, everything is plugged in i double checked..and what boggles my mind is that the computer is saying open circuit which usually means something is unplugged, but its not |
| All times are GMT -5. The time now is 10:08 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
