LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   LT1-LT4 Modifications (https://ls1tech.com/forums/lt1-lt4-modifications-31/)
-   -   10's on stock bottom ends (https://ls1tech.com/forums/lt1-lt4-modifications/1035763-10s-stock-bottom-ends.html)
TravisMcGill2000 Dec 19, 2008 12:22 AM
how many of yall are in the 10s with stock bottom. please list heads and cam combo's plus power adders if have any. my plans are to be high 10s by next racing season. thanks
daniel6718 Dec 19, 2008 01:02 AM
i did cam only with a 125 shot...auto and 3.73's
TravisMcGill2000 Dec 19, 2008 01:28 AM
wat rear end and cam if u dont mind
daniel6718 Dec 19, 2008 01:37 AM
cc306 longtubes ewp ls1 lid comp pro mags nsa guideplates and crane 10309 springs
fuddle 3200 stall
125 hit from hsw
stock rear end
robsquikz28 Dec 19, 2008 01:43 AM
do some searches there are several peeps on here that have what they have done to their cars
ZONES89RS Dec 19, 2008 11:02 AM
Seen it in a third gen, was a TH350, 4.10 gears, cam, headers(full length), and a 175 shot, went 10.26 if i remember right.
Z-RATED94 Dec 19, 2008 11:35 AM
Times in sig. Let me know if if you have any questions.
TravisMcGill2000 Dec 19, 2008 01:50 PM
wat rear do u have and wats ur race weight
thanks
BOLO Dec 19, 2008 08:38 PM
Stock shortblock here! 10.44@130 check out vid below in my sig.
LS1 SPEED Dec 19, 2008 08:41 PM
90K mile shortblock
stock ported heads /intake
230/236 cam
LT's ORY and 4" catback
TH350 w/ 4000+ stall...was too loose on spray
12 bolt w/ 3.90
150 shot
3400 ish race weight
10.52 @ 126
1.46 60 ft
Z-RATED94 Dec 19, 2008 09:27 PM
thanks
Stock shortblock, trans and 10-bolt. I don't know the race weight, but it's not light.
marc97taws6 Dec 20, 2008 12:13 AM
Wow, and your rear-end is still holding up good?
Maybe I shouldn't be so afraid of mine :D
Z-RATED94 Dec 20, 2008 09:20 AM
SHHHH, don't say that to loud. It's all a crap shoot. I really have no idea what's going to let go first.
LS1 SPEED Dec 20, 2008 09:26 AM
HA! The old trusty 10 bolt can shine if not abused to badly. The main thing that keeps it alive is the auto and loading the rear unlike a manual.
speed_demon24 Dec 20, 2008 10:33 AM
I know theres a H/C car running 10.7@128 n/a with the same h/c setup as me. Kind of makes me curious what I would run if I had a rear and a tire.
LT14LIFE JT Dec 21, 2008 07:59 AM
High 10s have been accomplished on a stock bottom end N/A, but it's not very common. 10s can easily be had with h/c and spray. My goal is to run high 10s/low 11s with boltons and spray. Don't know how much spray it will take, but I guess we'll find out..LOL
BizZzatch350 Dec 21, 2008 06:44 PM
On gas there was been an LT1 or two to go 9s with the stock short block.
Meen95z Dec 21, 2008 06:53 PM
I did a 10.97@125 on cc306, longtubes, 9"w/4.11's, stock lt4 heads, 58mm tb, 150 shot nitrous works kit, 3600 vig converter and the other little bolt on stuff.. I think I could have got a 10.90-10.87 given another chance or 2..
TravisTA Dec 22, 2008 10:09 PM
how high where you you revving it???
GreenbeanZ28 Dec 22, 2008 10:25 PM
Same guy goes 9's on spray. Got a friend of mine that went 10.1/131 mph with some home ported heads/shelf cam/stock bottom end/nitrous and he just switched to a set of AI heads. 9's should be around the corner.
© 2026 MH Sub I, LLC dba Internet Brands
