This can't be good...
Just not looking forward to draining the coolant, disconnecting EVERYTHING, pulling the intake and acc. bracket then everything else.
WOW, this thread is getting more responses than I thought!
The stock PCM rev limiter is still engaged so even when I let it run all out, it doesn’t pass that. It’s rare lately that I let it spool up like that but there’s been a few times.
I’ve had this setup for I’d say two and a half years, there’s about 35,000 miles on it. Many trips to New Jersey, one trip into Canada, it splits daily driver duties with my work van.
The valve train gear (cam, pushrods, rockers, springs, locks, etc.) is from Comp Cams, it came as a package from the good fellas at Advanced Induction along with the heads & intake.
The valve in question is stuck and doesn’t rotate. It’s bent. Hopefully, it didn’t hit or damage the piston.
The work is gonna wait until after the holidays as I have a guest visiting. I might be able to scrape together the bucks to fix the head, all new springs and any other nick-knacks I might need to R&R the heads & intake. If the piston took a hit, it’ll need more work and money of which I don’t have now and may not have for a while.
As far as any warranty from CC, I’d have to find the original invoice from AI and see exactly when I got it and what spring kit it is. I have a feeling it’s one that was affected but after all this time and miles driven, I doubt it there’ll be any coverage. At this point, my machine shop will decide what new springs to use, it’s a race shop and they do very good meticulous work and are well known in the Long Island area for their engines.
The work is gonna wait until after the holidays as I have a guest visiting. I might be able to scrape together the bucks to fix the head, all new springs and any other nick-knacks I might need to R&R the heads & intake. If the piston took a hit, It’ll need more work and money of which I don’t have now and may not have for a while.
As far as any warranty from CC, I’d have to find the original invoice from AI and see exactly when I got it and what spring kit it is. I have a feeling it’s one that was affected but after all this time and miles driven, I doubt it there’ll be any coverage. At this point, my machine shop will decide what new springs to use, it’s a race shop and do very good meticulous work and are well known in the Long Island area for their engines.
Well I hope you get it covered being those springs were possibly apart of the bad batch..I had a bad set but found out before I installed them...sucks man. Good luck!
#32
#33
OWN3D BY MY PROF!
^ It's located on the box the springs came in. It says the batch number on a white sticker / area on the side. Search bad batch 918 and you'll find all of the batch numbers and other info on it.
If your valve seized in the guide causing the spring to break I doubt they would cover it. At 35,000 miles you should at the very minimum had the pressure checked on the springs. Once you hit that level it's a good idea to replace them. They may have just been old and lost their pressure or cracked under fatigue.
#34
The heads were assembled by Advanced Induction, long ago, the box the springs came in stayed with them.
I didn’t think with quality springs that I should be concerned with occasionally checking their pressures. I’m assuming at this point that the failure was due to these springs being from that bad batch that CC had. If they are a bad batch set, I suppose I’m lucky they’ve lasted as long as they did.
I’m weighing all my possibilities at this time from pulling the heads, putting new springs in and rolling on to parting out the car and moving on to a LS Formula or even finding a decent 71 Monte Carlo in blue (of course!) to make my everyday ride. I’ve been through the gauntlet with this LT1 car and frankly I’m tired of all their issues.
#35
This makes me a bit nervous because I had my heads assembled by Advanced Induction around April of 2006, and I have the same springs. The difference is I only have about 4,000 miles on them since this was done. I wonder if I should check into my springs being bad.
#37
LS1EDDIE, you've dealt with AI and I'm sure you know as I do, they're stand up guys. If they need to stand behind anything, they will.
The CC spring problems aside (that surely affected any shop using them), I would still give the boys at Advanced Induction an A-number one rating.
#39
I have to agree with Dwayne. You should be checking them at least every 15k miles. Just because springs are good doesn't mean they don't wear out. 15k miles isn't that often. Once a year if you drive your car A LOT.
edit: Just wanted to add that if you really have 35k miles on those springs then IMO neither Comp or AI is at fault in any way. Also, this problem has nothing to do with your motor being a LT1. If you want to play with go fast stuff, you are going to break things now and then. Go get a LS1 or a Ford, Mopar, whatever you want, they all break.
