need a water pump welded
not weld the pump on i took off the hoses for the heater core that go to the pump and want to have them welded shut also the drive hole in the back off the pump that is usually freeze pluged no i dont want to ****** rig it this car will also see some car shows so no ugly block offs
Aluminum boat shops should be able to, as well as any custom fab place. I have several in my area. I could even do it if you get desperate. I mostly TIG thin wall chromo/stainless/steel for a living, but can lay a decent bead on aluminum and have a TIG in my garage. It looks clean with the pump welded and ground instead of freeze plugs and hose clamps. I am going to weld my rear pump hole when I put an electric pump in. I drilled and tapped the weep hole and installed a fitting to run a hose away from the opti too, but don't think that is necessary with electric. Also put a petcock in the pump to drain it fast for easy access to the opti.
