what rockers for LE2 h/c?
Old 01-15-2009, 08:56 PM
blake110106's Avatar
Default what rockers for LE2 h/c?
so I was planning on just a cam swap but decided to do H/C while the engine is out. I had already bought Comp magnum 1.6 RR's 1418-16. It says the max open spring pressure is 350.
On Lloyds page the PAC beehives will be 340lbs open and the max lift is .600 with the 232/240 cam I want to use and the rockers i have I will be close to maxing both. Should I just go with the patriots and other rockers for extra insurance? I
Old 01-15-2009, 09:23 PM
za355tx's Avatar
I would just go with the patriot springs. Lloyd suggested that for me and the cam I have is less than 600 lift. As far as rockers I would say majority of people use the Comp Pro Magnum rockers. They are super strong and ligher than most rockers. I wish I had a set myself.
Elliott's94Z's Avatar
You should be just fine with the CC.That's what I'm running and I ran it by him first and he said they would be more then fine. If they were gonna be a issue I would imagine he wouldn't have ok'd them.
Old 01-15-2009, 09:29 PM
see these aren't the Pro magnums. Just the regular magnums.
Old 01-15-2009, 09:36 PM
shutzero's Avatar
pro magnums with the patriot springs is what im going with when i get the money for it
Old 01-15-2009, 09:39 PM
James Montigny's Avatar
That's what I am using.
They'll last and they work great
Old 01-15-2009, 09:51 PM
shbox's Avatar
Until the Ultra Pro Magnums come out, I'd use the Pro Magnums, not the plain Magnums. IMHO, you don't want to put in a big cam and not do full roller rockers.
Old 01-15-2009, 10:04 PM
I believe im just going to sell these and go with something else.
you know when the Ultra pro magnum are suppose to come out?
Old 01-15-2009, 10:30 PM
SoxXpupPeT's Avatar
i have the regular RT magnums. good rockers. and cheaper. and still worth the money to upgrade
Old 01-16-2009, 01:14 PM
ss.slp.ls1's Avatar
+1 for CC ProMagnums.
Old 01-16-2009, 01:56 PM
Roadwarrior1956's Avatar
I had a set of those and had scoring issues on the 2 front sets from oil starvation, went with the Pro magnums, motors revs smoother, quicker, and feels stronger. They may be fine for a stock motor, but I would hesitate to use them on a modified motor
Quick Reply: what rockers for LE2 h/c?
