12's???
Old Jan 23, 2009 | 11:04 AM
ats5424's Avatar
Default 12's???
I've got a 95 Formula M6. 4.56 Gears, Pacesetter Lt's with true Dual Dynomax Bullets, Hays Performance clutch EGR Delete. New Opti Morosso 8mm wires and new plugs. Completely stock I ran the car to a 13.6. Car seems MUCH Faster. What do you guts think?
Old Jan 23, 2009 | 11:14 AM
buzz12586's Avatar
Put some drag radials on it. With a good 60ft you should be able to go high 12's.
Old Jan 23, 2009 | 11:15 AM
blackz6sp's Avatar
Mid twelves with sticky tires if full weight, low twelves with some weight removed.
Old Jan 23, 2009 | 11:26 AM
LSWHO's Avatar
12.999 may be possible with perfect weather and the perfect launch.
Your rearend will probably break if you launch the way you need to.
Old Jan 23, 2009 | 11:28 AM
ats5424's Avatar
Thanx for the info guys.
Old Jan 23, 2009 | 12:16 PM
buzz12586's Avatar
I ran 13.08 @ 108 with just CAI, Catback, tune, and DRs in good weather. He has headers and gears on top of that. With a decent 60ft it should go 12s.
Old Jan 23, 2009 | 12:17 PM
3DFORMULA's Avatar
Hookin' should help alot. I'd have to say it'd do 12's easy.
Old Jan 23, 2009 | 03:44 PM
LSWHO's Avatar
Ok and every mod you just listed, he didn't.
Old Jan 23, 2009 | 04:17 PM
Counted Out's Avatar
With those 4.56's you should be into 12's.
Old Jan 23, 2009 | 04:37 PM
TravisMcGill2000's Avatar
i went 12's with a 2.73. so u should have no problem unless you have traction problems
Old Jan 23, 2009 | 05:16 PM
buzz12586's Avatar
Yea he has headers, I didn't. He has gears, I didn't. All he needs to add is drag radials and it should go 12's no problem.
Old Jan 23, 2009 | 06:47 PM
94Zstangwalker's Avatar
i would think you should be in the 12s unless your spinning half way down the track...
i ran a 13.7 with just a K&N and a magnaflow catback... (before any other mods i have listed)... but if you can drive it or not with a 6 speed also effects it a LOT!
Old Jan 27, 2009 | 12:36 PM
ats5424's Avatar
Thank yall for the input. the tracks around here are closed until mid Feb. When it opens back up i'll let yall know how she does.
Old Jan 27, 2009 | 03:59 PM
LSWHO's Avatar
You clearly didn't get what I said.
You listed an intake, he didn't.
You listed a catback, he didn't.
You listed a tune, he didn't
You listed Drag Radials, he didn't.
Those 4 things could make QUITE a difference.
Gears and headers can do wonders as well, but without DRs they are worthless. And not every car will perform like yours. Not everybody has the same elevation, same weather, same DA. There are way too many variables and with ONLY the mods in his sig, he will NOT hit 12s.
Old Jan 27, 2009 | 04:09 PM
96lt1m6's Avatar
Sea level,ahh i miss sea level!
i see a sweet 60' coming!
definately in the 12s.....what size tire?
