My Dart 200s back from LME
Old 02-03-2009, 04:25 PM
Moderator
BizZzatch350's Avatar
Default My Dart 200s back from LME
I got the heads from Jim@TPiS, I then dropped them off with Bryan@LME. I went with their street/strip port job, mill and gasket match. The heads still have some potential left in them but after talking with Bryan this would be ideal for the set up I am running. It was cool to see they wanted to get me the best performance and value for the set up. I hope to start the install come March when i get back from off shore. I have a feeling this sucker is going to mean for what it is and should run hard on the bottle. The cam is a Comp CC306 and the intake manifold was originally ported by MTI back in the late 90s, I planto send it on up to silver ghost for some powder coating. Flow numbers are kind of like dyno numbers, don't mean **** going down the track but since that is going to be the first question and what most people will look at:
.100 88/69
.200 141/110
.300 190/145
.400 230/177
.500 265/193
.550 274/199
.600 280/206
.650 288/212
Old 02-03-2009, 04:33 PM
LS1 SPEED's Avatar
cool
I look forward to hearing about your setup coming together. The ALT/PS bracket is going to make some killer power
Old 02-03-2009, 05:19 PM
joelster's Avatar
I would go a little bigger on the cam. The 306 works good on stock heads, and you have heads that are way beyond stock heads.
Old 02-03-2009, 05:23 PM
OWN3D BY MY PROF!
Beaflag VonRathburg's Avatar
What all is it going on top of?
Old 02-03-2009, 05:45 PM
hashtagBMW
Speed Density's Avatar
A Racecar.
Congrats Neil, now get that thing back together!
Old 02-03-2009, 08:38 PM
Moderator
Thanks guys, I look forward to seeing how it runs.
It'll work well with these heads, I don't know if you guys remember Chris B, but he had that cam with a well worked set of LT4s from GTP, that car ran really well. Being a 93 and not having the equipment to burn chips. I'm going mail order. That was a big reason to go with this cam.
Old 02-03-2009, 08:50 PM
slomarao's Avatar
Question
Have you thought about a gm847?
Just an idea.
Old 02-03-2009, 09:02 PM
1badzee's Avatar
Definately invest the chip burner/emulator combo thing from MOATES. Probably one of the best things you can get for your speed density vehicle. I am ordering mine soon. I read the reviews and it's exactly what I need.
http://www.moates.net/product_info.p...products_id=54
Old 02-04-2009, 09:09 AM
SS MPSTR's Avatar
Absolutley nothing wrong with running a 306 - that thing should fly. Good luck with the completion of your project.
Old 02-04-2009, 10:44 AM
za355tx's Avatar
Go with an 847. You won't be sorry and tuning shouldn't be a problem.
Old 02-04-2009, 01:39 PM
FASTFATBOY's Avatar
On paper the 306 and 847 are similar arent they.
Old 02-04-2009, 06:48 PM
Moderator
I already have the CC306, not going to sell it for another off the shelf grind. I have also been around CC306 for the past 9 years, I know how they drive, how they run, it's a safe bet for a cam.
Old 02-04-2009, 06:56 PM
James Montigny's Avatar
/subscribe
Looking forward to seeing how that combo does.
