LT1 power help..
I hit 13.1 so far with only a stall, tune, 3.42s, LTs, ram air.
There's still more bolt ons to do too.
If you have a manual, then I'd go 4.10 gears, LTs, intake, tune, and Drag radials and you should easily hit 12s
If you have an auto, then my mods and maybe some 3.73s and rockers and you'll easily hit 12s.
Also, header bolts are notorious for backing out. That's why locking bolts are getting more popular.
Fix that leak and go from there.
You can get into the 12s very easily without touching the stock heads and cam and for cheaper than you might think. My old setup I used simple bolt-ons, a good sticky tire, and a prayer for my 10-bolt and went 12.9 @ 108.5 (headers, gears, big converter, free mods).
What Ram says. A customer of mine had a BONE STOCK,less stall convertor and a street tune. BUT, he had all the suspension work done, ran 13.00 flat on motor and with a 100 shot ran 12.02....
IMO in most cases traction doesnt break 10 bolts, wheel hop does
. I get around to it . If you want to see more on this car as it gets built check out my garage add me as a buddy and what not.
