Ignition coil for LT1
Old Feb 4, 2009 | 06:55 AM
BOLO's Avatar
Default Ignition coil for LT1
Is there a better coil for the LT1's? MSD, Accel,etc.?
Or is the original GM coil just as good?
Old Feb 4, 2009 | 07:09 AM
LS1 SPEED's Avatar
I still run an OEM coil, but to my knowledge the 96-97 have a better coil then 93-95. We still have a stock coil on a customers 95 that goes 9.7x's.
I do not think an MSD is needed, but it can't hurt replacing an old coil either.
Old Feb 4, 2009 | 07:16 AM
BOLO's Avatar
^Thanks Larry. I'll be replacing that too with an oem piece.
Old Feb 4, 2009 | 08:54 AM
multmigs's Avatar
X2 on the 96+ coil, its a bit better of a piece and costs a little less I believe, there is couple threads on how to change the wiring over, I did it last year, noticed no difference at the time but if you need one it can't hurt, only other thing is you will have to change the single wire to the opti and find the correct type of connector for the coil harness plug, I deleted my air pump at the same time and it just happens that the air pump plug is the correct connector...
Old Feb 4, 2009 | 11:58 AM
Black93_Formula's Avatar
i just recently put in an accel coil and i noticed jus a little difference in throttle response and quicker start-ups. i think u would probably noticed the same with an msd coil but either way ull notice a slight difference from the stock coil.
Old Feb 4, 2009 | 12:22 PM
moderate Z28's Avatar
I dont think you will really be able to notice a difference. Maybe a slight increase in throttle response. If I was going to replace a stock worn out one I would get one. I have an extra Accel coil for 93-95 LT1's if your interested. PM me.
Old Feb 4, 2009 | 12:44 PM
porksoda's Avatar
I got the MSD coil simply because I'm too lazy to even want to attempt to change the wiring over for a 96 and up coil. Didn't notice a difference but it does match my MSD opti I guess.
Old Feb 4, 2009 | 12:47 PM
R3DLT1's Avatar
MSD coil worked great with my car. I would consider it to any one
Old Feb 4, 2009 | 01:29 PM
1redta's Avatar
Default re
I've heard that the OEM coil is better than any other coil. make sure to space the coil from the head with a couple of nuts to allow air to circulate around the coil and ICM.
Old Feb 4, 2009 | 02:18 PM
RamAir95TA's Avatar
I've been using an MSD Blaster coil for 8 years - same one with zero problems and great results.
Old Feb 4, 2009 | 02:59 PM
wolfen's Avatar
i just got an MSD blaster as well, i like it. It takes a bit to install, but no complaints here.
Old Feb 4, 2009 | 03:42 PM
ElkySS's Avatar
wats with the rumor of newer msd coils failing easily? i have an msd coil and am trying to track down a miss
Old Feb 4, 2009 | 04:08 PM
Racin96ss's Avatar
The '96-'97 are a slight upgade over the earlier yrs. I run the stock coil still...
Old Feb 4, 2009 | 04:15 PM
leadfoot4's Avatar
I've had the MSD "replacement" coil in my car for about 7 years, or so. Works well....
Old Feb 4, 2009 | 04:16 PM
Hot94Z28's Avatar
I have had my MSD blaster coil for around five years now.
Old Feb 4, 2009 | 04:17 PM
OutlawZ's Avatar
I ran a Nology coil without fail for a few years. great spark energy and better throttle response....
great for nitrous usage as well....
can't hurt to use an MSD blaster either...
If you're seriously in the big boy neighborhood it's an HVC II or nothing.... that's what pro stock cars run and it's what I got..... but you need at a very least i believe a 7 series MSD ignition to power it.... it'll light up a small city....
Old Feb 4, 2009 | 08:01 PM
Racin96ss's Avatar
That is classic!
Old Feb 4, 2009 | 09:00 PM
shbox's Avatar
The 96-97 single connector coils are as good as most aftermarket ones. The 93-95 dual connector coils could benefit from an upgrade.
Old Feb 5, 2009 | 11:37 AM
CAMJAG's Avatar
I have the new style MSD blaster coil. Ill be installing it next week with a 6al box msd wires, and new delco plugs
Old Feb 5, 2009 | 01:33 PM
1badzee's Avatar
I've had an MSD coil. It was okay I guess. Now I run a new OEM coil from GM, and I have no problems. OEM **** for the win
