Splay Caps and Timing Sets
What splayed caps and timing sets are you running here? I need part numbers so I can get some stuff on order. I'm about to start the N20 build and I plan to splay the bottom end. Also, I'm pretty sure I have the GenII opti spark. Can I run a regular SBC Double Roller timing set since the opti is driven by the cam dowel??
I run the Pro-Gram Engineering splayed caps....... I think they are the best splayed caps on the market....
and as previously mentioned you need an EWP to run a double roller... Most run the comp cams one AFAIK....
But do discuss the pros and cons of your options.
You don't want to cheap out on something that critical.
Expect $300-500 in labor to machine for and set the caps.
Same ones the builder picked for my car.
also using the pro-gram splayed caps. very high quality and decent price. they said not to be used with a stock dipstick but it worked fine after a little cutting on the tube and stick.
The stock dipstick has to be cut short and you can never use a full dipstick with the motor running again.
Otherwise it will end up pushed to the side and over into the crank. (that would be bad)
I run a dipstick handle-only to cap the tube when the motor is running and keep a full dipstick in the trunk for checking oil when it's off.
I have the Pro Gram Caps. You can bend the dipstick around the cap and run the stock stick. I have done this on 2 LT1's and it has worked perfect. It does not come near the crank.
Just a thought.
Just a thought.
