2 stages of nitrous on my lt1 wet and dry
1 Post
I didnt get any feedback in the nitrous section so I though my lt1 could help me out. Im running the zex dry kit right now with a 100rwhp shot. I want to add another kit to spray another 100 shot but this kit will be a nitrous express wet kit. Will this work?
With your mod list it is unlikely a full 200 worth will be worthwhile over a 150-175, if the heads/cam/exhaust are not up to the task you reach a point where more nitrous does not really make the car faster.
Tuning the wet kit will be a bastard if you expect to tap into the existing fuel system as jetting will be all fouled up by the jacked fuel pressure the dry kit uses.
If you do this I would recommend a seperate fuel system for the wet shot.
1 Post
96capricemgr Thanks for the input. I didnt even think about the elevated fuel pressure on the wet kit. I think ill just sell the zex kit and go with a nice wet kit. You think a 200 kit wont make any more power than a 150 shot on my car?
FIRST of all zex rates there kit at the engine so a 125 is like getting 75 to the tires... secondly the wet kit by nx will rate theres at the tires so if you do spray it with the zex kit with the 125 out the gate you can spray it with the nx....but i would spray it with 125 out the whole with the nx then once ur in second gear spray the dry shot 100 only and it can be done but you will need to tune for this or atleast get a retard box for both shots.....and let me tell you a 200 shot you will feel...
Go both dry shots and run a HSW Interface & Microedge to control the fuel, timing and when to bring in the second shot. I sent my pcm out to get tuned to allow the Interface to take out more timing. Of course you will need bigger injectors but I think it is worth it. Interface will let you adjust for different size shots and allow you to gradually bump up the shot to what you like.
In March I am heading to PMP for test and tune should have my car up by then I just finished the tranny swap. You should head out there to I think the main thing the shot will depend on is how much you can spray out of the hole with traction. Then bring the second shot in high in the rpm band for less stress on the engine should be fun times. Just run as high octane as you can Laniers sells all types of race gas.
1 Post
I would love to run my zex kit and NX wet kit but as 96capricemgr said, The fuel pressure from the zex kit will be around 80 to 90 psi when the zex kit hits, so The jetting will be all screwed up on the wet kit when the zex kit hits.
^^^ Interested in both of those kits. PM me with more details and pics/part numbers if you have them.
Anyways, you guys keep talking about raised fuel pressure messing with the jets... I was planning on running a 125-150 wet shot. I already have it set up, just have to trace down this missfire and a couple other mods to install before I do anything else with it. The thing is, I was planning on buying the full racetronix fuel pump kit to bump my lack of pressure with my failing stocker. Now I have the fuel line from the wet kit running right off the schrader valve to the solenoid (actual valve core will be removed to allow the fuel to flow). Am I going to run into problems with this set up?
No you wont run into any problems because you will be running a wet shot. When you run a dry shot one of the ways the system adds more fuel is to jack up the fuel pressure and make the injectors spray more. With a wet shot you are introducing the fuel through the nozzle instead of the injectors so no need to raise the fuel pressure.
You are doing a good thing by upgrading your pump its good insurance you maintain steady fuel pressure and don't go lean.
