stock injectors
Old 03-02-2009, 07:29 PM
LT1_King's Avatar
Default stock injectors
could i use stock injectors on a H/C from lloyd elliot? do i HAVE to put 30#s? is a DD and i just wanna do the LE2 H/C the car won't see nitrous just NA i don't travel far in the car just drive around town
Old 03-02-2009, 07:31 PM
Elliott's94Z's Avatar
Delphi 37# through Racetronix..Lloyd will prob recommend the same ones with his LE2 pkg. Same ones I'm running on my set up.
RamAir95TA's Avatar
I would definitely not recommend it. You'll need at the very LEAST 30#ers...ideally 37#s. Your stock injectors will hate you.
Old 03-02-2009, 07:38 PM
LT1_King's Avatar
so at least 30's? where can i find some cheap ones?
Old 03-02-2009, 07:42 PM
I would just invest in some 37#. Be good for any future build as well.
Old 03-02-2009, 07:43 PM
GIZMO's Avatar
I would say that it depends on what cam and how much is done to the heads. The stock injectors are good for a bunch of HP.
Old 03-02-2009, 07:47 PM
GIZMO's Avatar
Too big of an injector will not work as well on the low end. You don't "grow" into injectors. You match them to your application.
TransAmdriv3r's Avatar
you can probably find some gtp injectors, I think ive heard they flow at 36 ? not completely sure though.
Old 03-02-2009, 08:53 PM
Formula350's Avatar
32# on our PSI.
Old 03-02-2009, 08:55 PM
I understand that but a Delphi 37# work well on the LE2 set ups and that's what he's thinking of getting. Running them myself with no issues and a few others on here are using them as well.
Old 03-02-2009, 10:41 PM
LM97Z's Avatar
I agree, these are the injectors Lloyd himself recammends with his LE2 package, along with a 58mm TB, i'll take his word!!
Old 03-02-2009, 11:10 PM
GIZMO's Avatar
Cool.
Quick Reply: stock injectors
