Cruise control in the way of cold air intake?
yes it will be in the way. the cruise control thing SHOULD be bolted up to the frame in that part of the car. looks like its sitting upside down from your picture. There should be enough room in that space to move it out of the way. Is there even a cable attatched to it leading to the throttle body?
normally its mounted(in reference to your picture) to the left slightly. it even looks like someone re routed the wiring harness to the box. it should be under the car kind of hidden. its definitaly been messed with by someone.
its fairly easy to get in that spot by removing the front tire and then removing the plastic splash shield. that whole space will be opened up then
Thanks for all of the quick replies. I will have to get under there and check it out soon. hopefully holes are already there so I don't have to drill any. I think the guy that owned the car before me was a little off. He thought he was a mechanic and everything but he seemed to cobble everything up. Even my fuel system has been messed with. Who knows what else is in the wrong place. Oh well, its still a fun car.
