Custom cams and Cam only sticky!Dyno Numbers! Track Times!
Well since so many people are always posting up cam only threads id like to just make a sticky so we have info on here for everyone to veiw.
Post all the info you can about your cam only setup, and specs of the cam if possable.
Also post what kind of dyno it was tuned with and if possable A/F ratio etc, and trap speeds
If you have track times, post up in detail your run and the track condictions.
1994 Trans Am
Valvetrain
Comp Cams CC503 (224/230 .502/.510 [1.5] 112 LSA)
Comp Magnum SA 1.6 Rockers
Comp Hi-Energy Hardened Pushrods 7.200"
Crane 10308-1 Dual Coil Spring Kit
Exhaust
Pacesetter Midlength Headers
SLP Loudmouth
!CAT
Intake
K&N FIPK CAI
Trickflow Elbow
Professional Products 58mm TB
Other
3000 stall (unlocked)
275/50/15 Mickey Thompson ET Streets
130k+ miles on motor
325rwhp @ 64xx rpm
4xxrwtq (forgot rpm, high torque due to convertor flash)
never got a clean run at the track
Valvetrain
Exhaust
SLP Loudmouth
!CAT
Intake
K&N FIPK CAI
Trickflow Elbow
Other
325rwhp @ 64xx rpm
1996 Trans Am
Valvetrain
Comp Cams (236/242 .550/.560 110 LSA)
Comp Pro-Magnum SA 1.6 Rockers
Trick FLow Pushrods 7.200"
Exhaust
Pacesetter Longtubes
ORY
SLP Loudmouth Resonator (dumped)
Intake
Moroso CAI
1LE Elbow
Edelbrock/BBK 52mm TB
Other
3500 stall TCI
Moser 12 bolt 4.10 gears
MadZ28 mail order tune
approximately 3400lbs raceweight
7.73 @ 87.8 MPH 1.66 60ft
No dyno numbers
Valvetrain
Exhaust
ORY
Intake
Moroso CAI
1LE Elbow
Other
3500 stall TCI
No dyno numbers
1 Post
1994 Z28
Valvetrain
GM LT4 Hotcam (218/228 .525/.525 [1.6] 112 LSA)
Crane Gold SA 1.6 Rockers
Stock Hardened Pushrods 7.200"
GM LT4 springs
Exhaust
Pacesetter longtube Headers
2.5" True duals
Intake
Homemade home depot CAI
stock Elbow
stock 48mm TB
Other
26/10/15 Mickey Thompson ET Drags
318rwhp @ 5800 rpm
344rwtq @4500 rpm
Ran 14.03 @ 98 mph @ 5,000 feet above sea level 2.0 6 ft all with a 146,000 miles on the long block. If the car were at sea level it would run 13.03 YES colorado sucks LOL
Valvetrain
GM LT4 springs
Exhaust
2.5" True duals
Intake
stock Elbow
stock 48mm TB
Other
318rwhp @ 5800 rpm
344rwtq @4500 rpm
1995 Camaro Z28
Valvetrain
cc503 (224/230 .536.544)
1.6 NSA ProMag rockers
Comp 918 Springs
Exhaust
Pacesetter Long Tubes
3" Xpipe - True Duals
3200 Stall
255/50/16 MT Drag Radials
MadZ28 Mail Order Tune
330rwhp@5800 through a 6speed
no dyno numbers with the auto yet
1/4: 12.32@114 1.88 60ft (6 speed)
1/8: 7.62@86 1.59 60ft (auto)
Valvetrain
Comp 918 Springs
Exhaust
3200 Stall
1996 LT4 corvette.
Stock best runs 8.33 at 84mph and 13.31 at 105mph at Beech Bend 1.9x 60 foot
With hotcam, 4.10s, no tune ran 8.0s at 88mph and 12.90s at 111. 1.9x 60 foot
With the above plus LT headers, pcmforless mail order tune it went 7.89 @90mph and 12.38 at 115mph. 1.79 60 foots on both at Atlanta dragway.
