need some help
need some help
i wanna know how to take my smog stuff off. got tuned and deleted that stuff so is there some things that need to stay or can u just unplug it ? anything helps thanks. looking for write ups or pics as well of it
you will need some block off plates for the egr. i had some thick stainless steel sitting around and cut it to fit with a grinder and used a part of a "cut your own" gasket material and its held for a while.
remove and get a little rubber end cap/plug for them.
note: make sure to leave the PCV on.
here are some links for a good visual.
http://shbox.com/1/temp_sensor1.jpg
http://shbox.com/1/egr1.jpg
A picture would really help use to know what you are talking about. i think it is just the plug that goes into the pump. just cap it off at your intake and then cap it off at your exhaust manifold and leave the fuse in otherwise it will set a ses light. and pull the pump out and call it a day.
