LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   LT1-LT4 Modifications (https://ls1tech.com/forums/lt1-lt4-modifications-31/)
-   -   Does AC Delco Make Decent Opti's? (https://ls1tech.com/forums/lt1-lt4-modifications/1094222-does-ac-delco-make-decent-optis.html)
NitrousJunkie Apr 3, 2009 10:34 AM
I'm in need of an Opti, found a guy with a low mileage AC Delco unit but I'm weary because its not a GM/Delphi.
Is there anything to be worried about with these? Anyone have any experience using AC Delco Units?
Thanks.
Elliott's94Z Apr 3, 2009 10:37 AM
AC Delco are great...then again what opti is great :)
GreatV8 Apr 3, 2009 10:38 AM
+1 that's what I'm running
dkishton1486 Apr 3, 2009 10:45 AM
Be leary....Just because its low milage doesnt mean he didnt get coolant in it taking off the waterpump
Elliott's94Z Apr 3, 2009 10:56 AM
^^True true..how much is he asking for it? Did he tell you about how many miles were on it?
transamws6_97 Apr 3, 2009 11:01 AM
If I'm not mistaken I believe delco optis are made my delphi
ss.slp.ls1 Apr 3, 2009 11:05 AM
Both actually. At first the OEM parts were made by AC Delco, later they were made by Delphi. Both are quality oem parts. You can't go wrong with either.
OP - I would suggest removing the cap of the opti and thread locking the rotor screws.
shbox Apr 3, 2009 11:33 AM
Thanks.
It's the same thing.
schwoch1 Apr 3, 2009 01:53 PM
Like the other person said, A/C Delco is Delphi and vice a versa. I have found that no matter who makes an opti, it can fail. I had to walk twice last year, once with a Cardone reman and once with a A/C Delco unit. Goes to show that anyone can have bad parts!!! I decided to get rid of it all 'cause I got tired of walking!!!
Mike
Formula350 Apr 3, 2009 01:57 PM
The Optispark is Delphi, but the OPTI(cal sensor) is Mitsubishi :D (Sorry, had to heh)
sweetbmxrider Apr 3, 2009 02:27 PM
its oem quality. stick with it!
Formula350 Apr 3, 2009 02:33 PM
Yep! Just make sure it's not an eBay "Remanufactured" unit unless it's by Thepartsladi (or something to that extent).
Also avoid Accel opti stuff like the plague, in case yo are planning to buy just the Optispark w/o cap and rotor (not sure if they even sell it that way).
© 2026 MH Sub I, LLC dba Internet Brands
