Get Rid Of Your Opti!!
http://www.eficonnection.com/eficonnection/default.aspx
http://www.eficonnection.com/eficonn..._cylinder.aspx
What Do You Guys Think? I think this is awesome!
Gauges should work on the swap, most of the gauges on the LT1 F bodys go from the sender directly to the gauge, no computer involved as far as I know. Speedo should work, but I am not 100% positive, and cruise should work if the speedo does, but again, not 100% sure. ABS should work as long as the car does not have traction control. If you have TC you are SOL as far as ABS/TC is concerned. The ABS has no interaction with the engine computer on the LT1 F body's, but TC does!!!
Emissions.... well, I can almost say that stuff like canister purge and air pump should work, but LS1 f body's did not use EGR, but the trucks did, so if you are hell bent on making your EGR work, use a truck cal. Most people that are game for this swap are not concerned about emissions, or are smart enough to know how to work around it in their state/county/community. I know here in Southeast WI, all vehicles '95 and older are exempt from emissions, and the '96 on up just get an OBD 2 inspection, no visual.
Hope this helps!!!
Mike
Hope this helps!!!
Mike
Hope this helps!!!
Mike
Hope this helps!!!
Mike
