heated o2's? I have a 1993 trans am that was tuned ofr bolt on's. All i have is lt's cai, and biger injectors. The car came with 22# injectors and i went with a 24# svo injector. The car wasnt running right so i had a very good local speed shop diagnose it. Turns out its running lean off the charts. I tallked to my tuner and he said that he doubts it is actually running that lean. He suggested heated o2's because of the lt's. Do any of you guy have to run heated o2's? I have the single wire sensor, where would i buy them? |
he also suggested that i remove the chip and see if it helps. Wouoldent it run really rich if i did that because of the bigger injectors? |
All 93 guys run heated O2's, if you run LT's it moves the sensor too far back from the motor and it doesn't get hot enough so it jumps in and out of open and closed loop. I have three wire O2's out of a 94 S-10 and I made extensions and wired them in myself. I know there is a member on here that sells a kit. I know Firebird is in his name. I dunno. I'm sure you'll hear from someone who knows. It may be easier to turn something up on speeddensity.org in their search. Good luck. |
Really? Evryone runs them? If it is an o2 sensor issue wouldent the car run fine untill it warmed up. |
look here http://www.fastbirdperf.com/93-97F-Body/93HeatedO2.htm and here is a write up on how to do yourself http://www.fastbird93.com/Installati...Conversion.htm more info could probably be found on speeddensity.org fixed links |
Originally Posted by 93TAJ.C.
(Post 11394916)
Originally Posted by Puck
(Post 11396153)
It keeps the car from going into closed loop, and makes the readings more accurate when it finally does. The Thunder Racing heated o2 conversion helped my idle and drivability a ton, plus the car gets into closed loop much quicker. |
Ok so my next question is do you have to run a fuse in the harness and run the wires all the way up to the fuse box? Can i just run the power to a ingnition hot wire and screw the ground to something close to the sensor? |
(Post 11397923)
Originally Posted by sepno77
(Post 11400755)
the way i did mine is i ran a wire over the trany into the fuse box inside the car and grounded it to the closes bolts i could find to the sensor. o and i didn't bother w/ the fuse. at 1st i did but then just got rid of it. works fine for me. |
Originally Posted by ss.slp.ls1
(Post 11396478)
PUCK...my car is about to look just like your sig pic. :)
(Post 11400755)
| All times are GMT -5. The time now is 04:00 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
