LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   LT1-LT4 Modifications (https://ls1tech.com/forums/lt1-lt4-modifications-31/)
-   -   Car Won't Start! (https://ls1tech.com/forums/lt1-lt4-modifications/1097901-car-wont-start.html)
RED PUNISHER Z Apr 9, 2009 03:12 PM
Car Won't Start!
This is extremely annoying. Here are the symptoms: when I turn the key to the on position, the fans and the fuel pump come on, but when I turn it all the way forward, nothing happens (no "click", don't hear starter crank. Don't think it can be the starter because it's brand new).
Can it be my clutch switch that is not letting my car turn on? It is not VATS. The security light is not on and I've done the resistor to bypass that last time.
My car wiring is a mess from the original owner, so anything is possible. I've gone through and cleaned up as much as I can so far.
I also noticed a couple of times when I was driving around town, after I parked and turned the car off, I had the key all the way to the off position, and pulled the key out and the car stayed on for about 3 to 5 seconds. I don't know why it does that, but that's the only thing that has been going on with my car, and now it does not want to turn on.
What can it be? Is there an ignition solenoid (cylonoid?) on the car somewhere, or what should I be looking at to see what might be causing this? Need help ASAP!
RED PUNISHER Z Apr 9, 2009 03:14 PM
also..
Also, I have no dash lights in the car.. none of the knob lights turn on when I have the headlights on. What can cause that? And what can I do to fix it? I took apart the whole dash to look for any burnt wires, I replaced all the fuses in the car and under the hood, but still no dash lights.
djjab57 Apr 9, 2009 03:19 PM
when you turn the key all the way does everything go out ? dash lights just nothing?
ss.slp.ls1 Apr 9, 2009 04:15 PM
Check your fuses, all of them.
Check your ignition switch.
RED PUNISHER Z Apr 9, 2009 04:27 PM
When I turn the key forward, to turn the car on, the gauges turn on but there's no gauge light. I already checked all the fuses from the fuse box inside and outside the car. None of them are popped and I don't know where the ignition switch is...
Any other ideas what it could be?
djjab57 Apr 9, 2009 04:27 PM
thats why i asked if everything went black when the key was engaged, ignition switch
djjab57 Apr 9, 2009 04:29 PM
when you engage it all the way what happens? the ignition switch sit on top of the steering column
ss.slp.ls1 Apr 9, 2009 04:55 PM
http://shbox.com/1/ignition_switch.jpg
© 2026 MH Sub I, LLC dba Internet Brands
