LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   LT1-LT4 Modifications (https://ls1tech.com/forums/lt1-lt4-modifications-31/)
-   -   HELP my car won't start either? (https://ls1tech.com/forums/lt1-lt4-modifications/1097902-help-my-car-wont-start-either.html)
slagger Apr 9, 2009 03:15 PM
hmm ok,
I just swopped pcm and it still won't start... I even reproramed it and put the VATS back on and it still won't start?
the security flashes when you put the key in and no start?
any clues
djjab57 Apr 9, 2009 03:26 PM
it's not turning over? if you have fixed your Vats it could just be your key. spray some compressed air in the key hole and clean off the chip thing on the key itself
ss.slp.ls1 Apr 9, 2009 04:13 PM
You could try cleaning your key, otherwise you might have a bad contacts inside the key cylinder. You could bypass your vats all together.
slagger Apr 11, 2009 12:59 AM
Yahooo I did the resistor bypass and it worked ;-)
ss.slp.ls1 Apr 11, 2009 02:08 AM
Nice. I've done it on several cars. Works like a charm. :)
marc97taws6 Apr 11, 2009 02:10 AM
Nice. I had my PCM tuned at SpeedInc and got it back and the car ran so much better! Like a completely different car! Hopefully you have the same results with yours
© 2026 MH Sub I, LLC dba Internet Brands
