are 6's possible so far i have ran 7.34@92 with a 1.54 60ft. my set-up is a 3200 stall, 1.6rr,cai, foil, pulleys, 3.42's, pcm4less tune, duel turn downs, lca, comp. eng rear shocks, ls1 d.s., plus a 125 wet kit. im still on 16x8s with mt dr's. race weight is 3450. what more can i do without changing the cam heads or intake to get in the 6's... thanks |
Originally Posted by TravisMcGill2000
(Post 11464789)
so far i have ran 7.34@92 with a 1.54 60ft. my set-up is a 3200 stall, 1.6rr,cai, foil, pulleys, 3.42's, pcm4less tune, duel turn downs, lca, comp. eng rear shocks, ls1 d.s., plus a 125 wet kit. im still on 16x8s with mt dr's. race weight is 3450. what more can i do without changing the cam heads or intake to get in the 6's... thanks -up your shot -1.7 rr's -EWP -weight reduction. No idea if that can drop your ET by .34 though. |
Yes, you can drop .34 and get into the 6s without touching your heads/cam intake - especially if streetability is not a concern. 3.73 gears or higher depending on your tire size and rpms at the end of the run, bigger shot of nitrous, weight reduction, skinnies up front, better weather, misc stuff like posted(EWP, tstat, etc), front drag shocks and a "suspension tune", etc. Just because you are not messing with engine internals does not mean it will be cheap though!! |
Upping the shot by 25-50hp and getting a bigger converter would probably get you into the 6s. Maybe you can improve the 60' some too |
k thanks guys. im going to a 1/4 mile track sunday. i will be trying a 150 shot for the first time. my be that will drop me a tenth or so.. im also going to try and take a little more weight out also.. thanks for all the advice |
It's definitely doable. Good luck! |
let us know what you do:D |
Originally Posted by mj114679
(Post 11469892)
Damn that trap speed is 10's territory! Good luck man! |
(Post 11505824)
went to the track yesterday on a 150 shot. it didnt break but it didnt run worth a crap. the track was horrible.the best 60 ft i could cut was 1 1.78 on motor. it was a 1/4 mile track and it ran 11.81@120 with a 1.88 60ft... previous best there was a 11.81@113 on 100shot with a 1.58 60ft 1.55 too 1.58 60ft. 7.13/7.15 1/8 @ 95-96 MPH 11.teens somewhere.................1/4 Might even hit 11.0s :chug: |
im going back to my local 1/8 mile track friday. so u will let yall know what happens. thats if the weather holds up.. |
| All times are GMT -5. The time now is 11:07 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
