Would this Exhaust Kit and Headers bolt on?
1995 camaro v8. all stock.
here they are = http://www.jegs.com/i/Pace+Setter/766/72C1335/10002/-1
they have 3" collector diameter.
this exhaust kit i want = http://www.jegs.com/i/Magnaflow/642/15620/10002/-1 - 3'' Stainless Steel Tubing will that work withe the CAT?
i was also thinking how can i get a Universal CAT in there without soldering it.
as for the CAT im thinking of this one.
http://www.jegs.com/i/Magnaflow/642/94319/10002/-1
Whats the Air Tube for ?
The purpose of the air tube is to inject are inside your exhaust to aid in the heating up of the catalist inside of the cat. By doing this it is able to burn off the extra gas a fumes that are released from your engine. It is only ran when the car is started up and then it shuts off since the exhaust itself keeps the catalist hot enough by itself. hope this helps
