LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   LT1-LT4 Modifications (https://ls1tech.com/forums/lt1-lt4-modifications-31/)
-   -   1995 TA T56 won't start-security light on!! (https://ls1tech.com/forums/lt1-lt4-modifications/1116635-1995-ta-t56-wont-start-security-light.html)
TRANSAM/FORMULA May 13, 2009 07:20 AM
my car is stuck at a gas station only because the oem security (vats?) is on. i took the battery cables off and put them back on after 3 mins and this has worked in the past. not this time. i want to find a way to eliminate this problem. i know that doing so is making my car easier to hotwire but better than being stuck somewhere. thanks.
duh May 13, 2009 07:56 AM
there are two 22ga. wires running down your steering column. if you reconnect them to the other side of the wires....fix the break and you should be good to go. These wires break all the time and the only way to fix it is replace the ignition switch with the one of 8 different vats equipped switches, or delete vats from your programming. It's truely a P.I.T.A!!!:bang:
ulakovic22 May 13, 2009 09:10 AM
Even if you delete VATS it wouldn't start.
As mentioned above it sounds like the wires in your column have a break in them somewhere. It's a common problem on older cars. These wires measure the resistance in the chip in your key and that resistance must match the stored value in your TDM/BCM within a certain %. If not the car won't start. There are a couple tests you can do by jumping the resistor wires or the relay switch.
http://shbox.com/1/pass_key.html
ss.slp.ls1 May 13, 2009 11:52 AM
http://shbox.com/1/air_bag_disc_2.jpg
Wire in a resistor to match the resistance of the pellet in your key at the point marked in the diagram above.
TRANSAM/FORMULA May 13, 2009 11:57 AM
thanks for the info. i left it for four hours and put the terminals back on and it started right up. i know that it will happen again sometime. probuly will happen at the worst time. i only drive for 20 minutes on a open toll road to work and i was very gentle on the gas as i was low on gas. maybe that's the problem keep, i need to haul ass to work. lol. well i will look into it shbox and see if i can do this resister thing. untill then this is no getaway car!!
Kaoz May 13, 2009 05:20 PM
There are modules out there for Vats delete. Its how we're able to swap the LT's into older cars without the chipped ignitions an keys. They're pretty easy to install and just emulate the same thing that was said with wiring in a resistor only this way you don't need to try and figure out which resistance chip your key has.
© 2026 MH Sub I, LLC dba Internet Brands
