Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Air Intake and Exhaust Guides
- Camaro and Firebird: Intake Manifold Reviews and How to Replace
Review and how-to
Intake Manifold Gasket Replace.
if my car never lose oil even after 3k miles drive, im good right ?
If you don't want it to leak again Use Ultra Copper or "THE RIGHT STUFF". Nice thick bead. That little tube won't do.
BTW do yourself a favor and blue loctite the manifold bolts. I took my manny off after 4yrs (to swap to a powdercoated one) and the bolts were still as tight as the day I smeared blue goo on them, and torqued them down. DON't **** around, do it right the first time around.
I snapped a cam retainer bolt doing mine and thought I was screwed since it broke on an angle and had red loctite on it.. got some small easy outs and a left hand drill bit and tapped an indent in the center of the bolt w/ a punch to get it started right then took the LH drill bit to it and never even had to use an easy out (thanks ls1tech!)
first time was because i wanted to paint my manifold
second was because i put a 58mm tb and didnt want to "port" the manifold on the engine
third was when i put my 355 together
plus iirc doesnt the felpro set come with injector o rings so you can unbolt the fuel rails??
#32
nope. we did my iintake manifold, valve cover, and oil pan gaskets and we didn't touch the cooling system. i still have my throttle body cooling lines in place so we just unbolted the TB and left it in the engine bay.
#34
Gel Time
Two questions.....what is the best size BEAD of RTV to apply along the surface area and after applying it someone said to let it wait 24 hrs. Is that simply applying the BEAD and allowing it to gel first and then lay the manifold on the block for twenty four hours allowing the weight to settle it and then snug the bolts with a final torque after?? I'd Like to do it right the first time. Thanx for the great info. !!
#35
Village Troll
I've always just applied from a tube of Ultra Black w/out the plastic applicator. Bead is about a 1/8" thick if I were to guess. What is meant by waiting 24 hours is after the manifold has been torqued, to wait that long for the sealant to cure before starting the engine. I've applied both ways- either waiting for bead to gel a little or just putting the manifold on immediately after applying sealant with success either way. The secret is to make sure all surfaces are spotless and to drop the manifold square onto the engine w/out moving once manifold is placed on the engine. And as already stated, make sure to check the torque of your manifold bolts after a few heat cycles.
