Oil leak.. need ideas
Car is leaking some oil when driving for a while. A nice sized puddle forms underneath the car when I park. When I first start it up, the driver side header burns oil (obviously oil is leaking from somewhere). I checked out the oil pan gasket, oil filter and rear main. Everything checks out okay. Last thing I can think of is the oil pressure sensor on the driver side of the block (93' location). That would make perfect sense as to why only the driver side header is burning oil. Any ideas? Oil pan is dry, but wherever it's leaking from, the oil obviously travels further back as I'm driving (covering everything in oil). Oil pressure sensor doesn't feel like there's any cracks in it (but then again I can't tell without taking it out and looking at it - and those of you who have it on the driver side block know how much of a pain it is to get to it without the right tool, which I don't have lol) Halp!
That's what I suspected at first as well.. Then to find out that they are both dry and clean, I was really befuddled I'm hoping it's the oil pressure sensor. I'll check that out sometime this week. Car's running great though and TH350 swap was a success. I just want to get rid of this leak before I take it to the track
pulled the oil pressure switch off.. and the o-ring (that's between the plastic part and aluminum part of the switch) was torn and sticking out. Could this have caused my oil leak? I mean, it is a pressurized source, right?
