otvc wires with pacesetters lt's? Can you run OTVC wires with pacesetters or is stock routing better? |
Originally Posted by ssbowtie1
(Post 11953959)
Can you run OTVC wires with pacesetters or is stock routing better? PM 99BlancoSS I think is his sn, he makes them with MSD wires cut to fit. |
does he make these to clear larger V.C.? |
They're really not difficult to make, just time consuming. |
I currently have the otvc wire setup on my jet hot lts. I finally got sick of the slip fit leaking and rattling so I'm pulling them out and will be replacing them. I was initially going with the coated pacesetter headers/ypipe for about $500. Then I found the pacesetter knockoff stainless steal headers on ebay for $400. At that price I can't help but try them. I just wanted to make sure I could keep the otvc wires since the pacesetter primary design is much different than the jet hots, especially on the driver's side. |
WOW i have the slip fit Jet Hots and haven't had any problems |
| All times are GMT -5. The time now is 04:53 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
