Is this re-useable???
Old Aug 4, 2009 | 02:07 PM
Z28Camaro30Ann's Avatar
Default Is this re-useable???
Ok, so most of you have seen my posts about my failed cam swap and broken pushrods/bent valves...
I just put 4 quarts of brand new oil into the car before I attempted to start it (5th was going in once oil cycled a slight bit). Again, it NEVER started up.
Same thing goes for the coolant...
When I drain this stuff to redo my cam swap and replace the valves, as long as I am careful for debris.....can I put it back in after and save some bucks instead of buying ALL NEW oil and coolant????
Sorry if this seems like a stupid question, but I wanna make sure and get opinions...
Old Aug 4, 2009 | 02:53 PM
AChotrod's Avatar
Id reuse it as long as you keep it clean.
Old Aug 4, 2009 | 03:22 PM
nik1703's Avatar
why not! I reuse coolant all the time, oil shouldnt be a problem either
Old Aug 4, 2009 | 03:56 PM
ss.slp.ls1's Avatar
I would get new oil, but that's just me.
Why would you try to start it and heat cycle it being a quart low? Why not just fill up all 5 quarts before you start it ever?
Old Aug 4, 2009 | 04:06 PM
1slo_camaro's Avatar
From: Born/Raised North East, MD Lived in VA, NC, MI Back in Yorktown, Va
i would reuse the coolant as long as its clean. but oil is only a few bucks i wouldnt spare something like that ecspecially if its first fire up after something that is soaked in oil. IMHO its not worth taking the chance of wiping the cam out or the bearings cause one lil tiny piece of debris gets in something it shouldnt lol
Old Aug 4, 2009 | 04:10 PM
AChotrod's Avatar
it never fired so Im sure the oil is good as long as there are not any missing chunks of pushrod
Old Aug 4, 2009 | 04:39 PM
idk to me oil is like a condom once its pulled from its package it shouldnt be used again hahaha. just something weird about it.
Old Aug 4, 2009 | 07:38 PM
AChotrod's Avatar
LOL!! True but Ive taken it out of my cars b4 and used it in my DDs if I had to drain newer oil for some reason and the DD needed a change. Never had a prob.
I would NOT do it at all if the car was running and **** broke.
I actually just dumped 5qts of RP with less than 100 miles on it, because my rocker arm broke...well I actually tore the entire motor down. To make sure everything was out and in good shape, but thats just me. I even strained the oil looking for parts and still tossed it.
Old Aug 4, 2009 | 10:25 PM
fleetmgr's Avatar
Used coolant is very unlikely to kill your engine if it has a bit of crap in it. If you want a bit more safety from your used coolant, filter it through cheese cloth as you pour it in.
Contaminated oil is VERY likely to kill your engine, and things that are too small to see with your eyes can do it. Oil is too cheap to risk it.
Old Aug 4, 2009 | 11:09 PM
ok ok ok OK! I'll buy more oil! lol
Old Aug 4, 2009 | 11:20 PM
fleetmgr's Avatar
I KNEW you'd see the light, LOL!
Old Aug 4, 2009 | 11:28 PM
lol..I saw it before...I was just trying to throw on some cheap sunglasses lmao
Old Aug 5, 2009 | 05:43 AM
looks like you have a pretty damn good looking car and looks like she can move pretty quick too. so no sense in trashing it all with shitty ****. dont buy crappy sunglasses from 7 eleven. go to a damn sunglass hut so you can get a pair of oakleys or dragons hahahahahaha. good luck with it man. and post up some pics i wanna see what your car looks like.
Old Aug 5, 2009 | 09:53 AM
I have a few in my garage on here, but it looks different now...powdercoated intake man, powdercoated valve covers, powdercoated TB, smoked corners and side markers and taillights, new exhaust tips, and fuel rail covers
Old Aug 5, 2009 | 10:04 AM
well get her clean and post up some pics!!!!!
Old Aug 5, 2009 | 10:05 AM
will do
Old Aug 5, 2009 | 10:30 AM
hammrman31's Avatar
Looks like a nice car. Good luck with the build, and post up pics.
