EVAP Delete?? I tucked my fuel lines yesturday and in the process decided to loose the evap line. I'm planning on removing the solenoid but is that going to be a problem and cause the SES light to appear? I had Ion loose the air and egr codes, but can't remember if I told him to get rid of the evap codes. Is the SES light for evap going to put my car in a limp mode or will it run the same with the evap code there? I found my old tune sheet and here is what I had him do as far as options go Powertune selected. Disable speed limiter. Disable Skip Shift. Disable EGR. Disable AIR. Disable CCP codes. |
If they disabled CCP - you're gold. The Evap is CCP - I believe it stands for Charcoal Canister Purge. |
Even with the EVAP Code it won't go into Limp Mode.. that isn't an essential function. |
Is the Evap delete as easy as the EGR delete? Like do I just unbolt and pull out everything connected to the hose? |
^^ I am interested in this, I am getting rid of all emissions because 1. They rob power. 2. We have no emissions control in Bahrain! |
^^That and cheap gas. |
Originally Posted by porksoda
(Post 12023746)
I did the evap delete. It took me 10 min. The hardest part was taking the rear driver side wheel off so I could get to the stupid canister lmao. It was cake and it cleans up the engine bay a little bit...gets rid of those useless solenoids and lines running around in there. |
And as stated above...if you had the CCP Deleted, your good, that took care of your evap system... |
Nice, I'll be removing the rest today and hiding some more wires :D I pulled my inner fender to hide the fuel lines and drill a new hole so I cut it down there. Now I just need a cap for the TB and clip off some wires and tuck them into the harness (taped off of corse) Thanks guys. I'll have the car back home tomorrow if all goes well and should have some pics shortly after |
cap for the TB? You mean the intake manifold?? The evap hooks up right next to where your Opti Vent tube hooks up, and your PVC hose runs. There are 3 nipples right there for lines...one of which is the EVAP...cap that one off. There is nothing from the EVAP on the TB though |
^^Mine was a 1995, the EVAP was on the Passenger's side. |
lol my bad, I didnt know it was opposite on 95's. But still its not on the TB is it? |
Originally Posted by Z28Camaro30Ann
(Post 12024127)
got ya |
(Post 12024442)
got ya The plug for the EVAP solenoid is cut and tucked back in the loom now, my intake tube is painted, and the TB is capped off where the EVAP hose ran into it. Tomorrow I'm finishing up the brake install, extending my MAF wires (just have to figure out how to run them up in front of the radiator where my intake tube is now) I'm getting kind of excited though, the last time I drove it was in April :( It sucks not having any money and a bunck of stupid little projects that just kept on going wrong |
Didnt mean to confuse you...someone tinkered with mine I guess cause mine ran to the driver side of the intake manifold for some reason |
(Post 12026835)
Didnt mean to confuse you...someone tinkered with mine I guess cause mine ran to the driver side of the intake manifold for some reason But I'm off to try to button everything up and hopefully drive her home tonight |
No check engine codes :D took the car out 2 nights ago with only high beams headlights (lows were out for HIDs) and wow is that scary not being able to see anything. The only time I could see the road light up was when I was getting on it but as soon as I let off I couldn't see shit. HIDs went in last night and WOW, thats all I can say. 4300k HIDs is where its at IMO |
Gas tank vent line. Will the gas tank vent line that went to the purge canister develop condensation that will get in gas tank? Can I leave just this line attached to the purge canister? Will doing this prevent condensation, and lower gas fumes? Thanks |
© 2024 MH Sub I, LLC dba Internet Brands
