A4 to M6, your experience?
Those that have done it, what are some estimated costs?
), flywheel and pressure plate bolts $60 (Local dealership raped me
), lower shift boot $35, M6 center console plate $50 and a few misc pieces here and there probably less than $50.But now my throw out bearing is going out
deffinately replace that if your going to be using a used pressure plate like I was. But I couldn't find one locally so I ran the old one, don't do that LOL If you do the swap I would suggest trying to find all the parts from one place, like someone parting out an M6 car. This will save time and money as you will not have to go searching for parts. The only things I had to buy other than the trans and components were a new clutch and center column insert(I wasn't able to find the 97 style uses anywhere).
$1200- Stock T56
$1000- Tex OZ700 Clutch Kit
$220- B&M Ripper Shifter & Ball
$175- GM Stock Master Cyl.
$175- GM Stock Slave Cyl.
$50- Cross Memeber
$40- Petals
$30- Center Console Cover Plate
$10- U-bolt for Master
Bronze Pilot Bushing was free..there was an extra at the Shop.
I got the Lower Shift Boot for free from a local guy.
-Dustin-
My car started auto and I just hated everything about the auto. I got too good of a deal on the car to pass it up though. But if you are thinking about the swap, just do it and you will be happy. nothing like a trans as bullet proof as a built TH400 with the overdrive of a 4L60e.
definately alot lighter than a TH350/400 with a GV OD too with less loss
pretty much like alot said, everytime I'm at the track and running away from my t56 buddies I love it but when I'm messing around on the highway or just blasting away on deserted road I wish I had a t56, oh well maybe it's time for a FMV
