Can you run NO 02S
if you want your car to run like boiled ****......
without o2's it will have no reference for stoich (lean vs rich) and will run like a tank. It'll probably go into some type of pcm based limp mode and just fuel the **** out of it so it'll run but not very good..... far enough to get you to a repair shop most likely.... WHY would you want to do that???
If you mean unplugging the front ones, then yes, it will run. In open loop. And you will burn gas like it's cool. You would have to have a very good tune, since all it will be running off is the preset AFR tables. It will run just like on cold start-up.
If you mean the rears, then yes, you can just unplug them with no adverse effects. It will throw a code though.
