few more questions
Old Sep 3, 2009 | 12:30 PM
97badass's Avatar
Default few more questions
how do you get rid of the AWFUL vibrations once you get going fairly fast?
will a 95 lt1 throw the egr codes and set off the SES light?
4th gear jumps out after the car has warmed up? bad synchro?
slow as ***** i beat a riced out fart can civic yesterday idk what all he had but i seen 3 gauges on his pillar i beat him by 2 car lengths the first run and then by a fender the second run. why so slow? or is it faster than i think and he is possibly FI? i couldnt hear ****!
car rumbles like it has a cam in it loud and obnoxious? any way to check without pulling it apart to see?
i think thats it.
is the speed sensor in a 93 m28 different than in a 95 t56?
Old Sep 3, 2009 | 12:52 PM
Z28Camaro30Ann's Avatar
What kind of vibrations??? Is it at certain speeds? Is it constant? Does it progressively get worse then go away?
Could be a number of things. I had a weight come off of my driveshaft once and it cause a horrible vibration from 80 to 105 then it smoothed out a bit but was still there. I got the DS balanced and never felt it again.
Old Sep 3, 2009 | 03:08 PM
97badass's Avatar
it comes on once i hit 55 according to my speedometer lol but more like 80-85 i cant stand to go any faster because its awful its like rumble strips on both sides with half way flat tires.
Old Sep 3, 2009 | 03:17 PM
Sounds like your driveshaft is out of balance. Take it to a drivetrain shop and they should be able to balance it for you. It is cheaper if you pop the driveshaft off yourself and take it to em...
Old Sep 3, 2009 | 03:33 PM
kinglt-1's Avatar
^yep sounds like driveshaft to me also! You can get it rebalanced for about 40-60 bucks depending where you live. Some will say get an ls1 driveshaft, but to me its a downgrade on stregnth. Balance the stocker or buy an upgraded unit imo.
Old Sep 3, 2009 | 03:34 PM
97badass's Avatar
i was about 99% sure thats what it was... but either way i go it still sucks.
Old Sep 3, 2009 | 07:18 PM
nah, if you want a cheap fix, pop the DS off yourself...doesnt take much...upgrade the U-Joint if needed...take it to a shop and they will balance it for like 40-60 like king said...re-install. Good as new for less than 100 and maybe 30 minutes total of personal labor.
Old Sep 3, 2009 | 07:24 PM
dirtynorth's Avatar
could also be that your tires are just out of balance
Old Sep 3, 2009 | 07:30 PM
97badass's Avatar
tires are brand new and balanced the driveshaft has new u joints too
Old Sep 3, 2009 | 07:35 PM
AChotrod's Avatar
Im still betting its the stock DS. Find aused ls1 aluminum DS and swap it yourself in 20minutes
Old Sep 3, 2009 | 07:38 PM
97badass's Avatar
i am agreeing its the driveshaft as well. or a bent axle maybe? but with a bent axle it would be there all the time right?
