Single Plane vs. Stock intake on 383
Ok, I'm still in the air about doing a single plane. I think if I ever do it though, I would get the intake modified and not the heads.
I am going to be running a 383 with TFS 195cc heads that flow 313 at .600, 2.08/1.60 valves, a 236/242 .612/.612 110+4 cam.
Right now I have a LE ported stock LT1 intake and just was wondering how much of a gain I would see from doing a single plane?
Eventually I am going to put nitrous back on it and I know that the single plane will have better distribution than the stock one.
what do you guys think?
You NEED to get the cam specific for whichever you choose.
I would get a Vic jr with that small of a cam.
Have the intake modified, send it to Bret Bauer he knows whats up with a super vic.
My super vic is just touched up in the plenum and match ported to the heads, he said I have 20 hp to get with his modifications.
hashtagBMW
Dont just get the intake to have it, you should 'need' it or you are leaving power on the table.
The following users liked this post:
NewOrleansLT1 (01-06-2023)
A few years ago, a local guys built a serious 396 with AFR 220 Competition heads and a big solid roller. He dyno'd it with the SP and a ported LT4. The LT4 made more power below 5200 rpm, they were dead even from 5200 to 6200, then the SP pulled away above 6200 rpm by a margin of 15 hp at peak. Not worth it IMO.
Yeah, I've been discussing it with some people and being that the car is mostly going to be a street car I think I am going to be better off just staying with the LT1 intake.
I am getting ready to install a single plane on my new build. 383 w/ Trickflow TEA heads and a solid roller. I am going to use a elbow and 90mm TB. This should work great with my YSi and 20lbs of boost.
I will let you guys know results when the car is done.
