Pacesetter ORY slip over or into GMMG?
Just like the title says. Putting the pacesetters on and got to the y. So does the ps ory slip over the gmmg or the other way around because they both look like they are the exact same diameter. I can't get them to easily go together so do I just need to break out the hammer, lol? Thanks guys.
The machine they use to flare the pipe is not movable.. so idk if they can do it without cutting some off your catback Chris...
They could get about 4-5" of 3" pipe and flare one end then weld the non-flared end to you catback, Or just cut about 4-5" off your catback so itll still be stainless then weld it back on.
Or just go wth that 3" band clamp. be easy ON and OFF..
Kris
Kris
