guys with LE heads come in
Old 10-13-2009, 08:36 PM
Restricted User
kalebm22's Avatar
Default guys with LE heads come in
will the le2 head raise my shift point over the stock heads with a cc503 camshaft?
Old 10-13-2009, 08:46 PM
myltwon's Avatar
if you're getting LE2 heads I'd get a better matching cam IMO
Old 10-13-2009, 08:54 PM
LS1TECH Sponsor
NightTrain66's Avatar
It will keep pulling another 400-500 RPM over what it does with stock heads. You do not "have to" raise the shift RPM but the car will be faster if you do. Just shift at 6300 RPM or so and the bottom end will live a while.
Lloyd
Old 10-13-2009, 09:09 PM
Restricted User
kalebm22's Avatar
Lloyd
thats what i was wondering, 6300 is wat my shift point is now but im sure i will want to raise it once i have you grind me a better cam.
Old 10-13-2009, 09:30 PM
LS1TECH Sponsor
if it is a 6 speed, you might shift at 6400-6500 RPM and still be OK, just do not go beyond that with a stock bottom end.
If it is auto trans and you have the computer set to shift at 6300 RPM (and completing the shift at 6500-6600 RPM) that is all I would wanna take the engine.
If it is a built 355, you can shift at 6500 RPM with no worries and a larger cam would be agood idea. If it is a stock bottom end, that is actually a good cam to make the bottom end live.
You would not ahve to raise the shift points and if shifting that high on a stock bottom end, just leave the shift points there and the car will still run ALOT better than it does with stock heads.
Lloyd
Old 10-13-2009, 10:28 PM
Restricted User
kalebm22's Avatar
ok, that sounds good to me, my car is an auto but i was thinking of goin with a 230/236 duration cam with a 109 lobe seperation. would that be far to much for a stock bottom end?
Old 10-14-2009, 12:06 AM
86formula's Avatar
goals for the car? i went 11s almost full weight with a 224/230 cam, its not bad on the street either
Old 10-14-2009, 02:14 AM
robsquikz28's Avatar
Yes a LE1 cam will suffice with a LE2 heads and make damn good power. You will just have to tell ur tuner who already knows to up the shift +/- 600 rpm which will be around 6400 rpm and will be awesome for your build. But if your bottom end is built push it further than that.
Old 10-14-2009, 07:55 AM
wrd1972's Avatar
Thats what I got. I made 384 through the 9" Truetrac and that was before my TD's, 58mm and better flowing CAI.
Old 10-14-2009, 10:28 AM
AChotrod's Avatar
I shift at 67-6800 with a LE 230/236 cam on my LE2s. So far went 11.68@119.12
Old 10-14-2009, 10:37 AM
djjab57's Avatar
I have the LE 226/234 cam glad to see your in the 11's. I also have the LE2 heads and ported intake
Old 10-14-2009, 03:47 PM
Restricted User
kalebm22's Avatar
my goal for the car is to be in the high 11's with a stock bottom end and on street trim. so now im thinking i might just put some 1.7 rockers that ive got laying around on and up the lift to .570/.580 and see if that will open them heads up a little more. also the car weighs about 3600 pounds with me in it.
Old 10-14-2009, 04:30 PM
AChotrod's Avatar
I would make sure you can even use 1.7s with that cam b4 throwing them on. With my cam I cant use 1.7s.
Old 10-14-2009, 05:07 PM
Restricted User
kalebm22's Avatar
why cant u use 1.7s?
Old 10-14-2009, 05:22 PM
strokin93z's Avatar
Probably too much duration, and not enough piston to valve clearance
Old 10-14-2009, 05:44 PM
Restricted User
kalebm22's Avatar
i wouldnt think i would have a piston to valve clearance with the cc503 would i? ive seen cams with alot more duration and more lift than that. so should i stick with 1.6s or go ahead and go with 1.7s?
Old 10-14-2009, 05:45 PM
AChotrod's Avatar
probably too much duration, and not enough piston to valve clearance
x2!!!!!
Old 10-14-2009, 06:12 PM
strokin93z's Avatar
I was talking about AChotrods cam, and such. best thing to do is check, its not that bad to check. Good Luck!
Old 10-14-2009, 07:00 PM
AChotrod's Avatar
I never looked into the cc503 thats why I said to check b4 you spend any money.
I can not do it with my cam for the reason Strokin mentioned, cam was designed to work with 1.6s.
Old 10-14-2009, 07:31 PM
Restricted User
kalebm22's Avatar
how do i find out before i spend any money?
Quick Reply: guys with LE heads come in
