LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   LT1-LT4 Modifications (https://ls1tech.com/forums/lt1-lt4-modifications-31/)
-   -   Poppin' the z's track cherry (https://ls1tech.com/forums/lt1-lt4-modifications/1195568-poppin-zs-track-cherry.html)
Johnny-LT1-runner Oct 22, 2009 07:53 PM
I will be takin this car for it's first track run ever tomorrow night.
I'm expecting the worst but would like to get your opinions on what it might run.
Current mods are 4.10's, an aggressive tune, some miscellaneous weight loss, a stock LS1 aluminum driveshaft, TB bypass, and a cheap welded thrush muffler dumped after the axle. And some brand new street tires to make it spin.
Any thoughts on this?
Edit: I'll post up my times later so we can criticize my performance, lol.
Elliott's94Z Oct 22, 2009 07:54 PM
I'm no good at predicting times...good luck to you though!! :)
LT1 Oct 22, 2009 07:58 PM
I would say about mid 13's
Badazz 97 TA Oct 22, 2009 08:29 PM
maybe a 8.8 1/8th. 13.8 1/4mile 102mph
madhatter Oct 23, 2009 06:37 AM
If you can get traction, which I doubt being a newbie, 13.60s. But I am guessing a 14.30 is in your future.
Wish I could have popped my cars cherry, but she is like the fat chick that got skinny and hot. Extremely used and abused by the time she is older with no turning back. :)
BlackScreaminMachine Oct 23, 2009 07:33 AM
Daterape, I do not see what trans you have..... (assuming m6 on the rear gear choice)
M6 14.0-14.2
A4 13.8
:jest: on the Cherry bustin
Johnny-LT1-runner Oct 23, 2009 09:14 AM
M6 14.0-14.2
A4 13.8
A4. People say 4.10's are crazy, but they're fun.
Here's the track site if anyone is curious.
http://www.thunderroadracewaypark.com/
BlackScreaminMachine Oct 23, 2009 10:57 AM
Well there is not much you can do. Id drain your washer fluid, pump up the front tires to hard, remove the rear and passangerside seats, spear tire/jack. Id avoid the water box, clean off the tires and then let the car leave off idle and what ever the stock stall will give is prob the best your gonna get.
4.10's may spin so your going to be playing with throttle depending on the 1st run goes.
You could also pull the filter (air), keep it in the car, pull off the side of the track and put it back in.
Johnny-LT1-runner Oct 23, 2009 11:19 AM
I removed the back seats last weekend, the spare and jack came out the first day I had the car. Good point on the tires.
Unfortunately there is no way I can avoid the water box at this track.
Badazz 97 TA Oct 23, 2009 11:48 AM
whats your rpms like on the highway with those 4:10's. say 75mph?
Johnny-LT1-runner Oct 23, 2009 01:22 PM
At 70 I'm at 3100. Coming from 2.73's the entire shift band is now 1000 rpm higher.
Johnny-LT1-runner Oct 24, 2009 01:20 AM
Best run of the night, and I beat my friends LS1 Z28.
http://i727.photobucket.com/albums/w.../Timeslip3.jpg
stangslayer98 Oct 24, 2009 02:01 AM
not bad you got the r/t..the car on the left looks like he had trouble launching, his mph with a good launch should net high 12's
Johnny-LT1-runner Oct 24, 2009 02:14 AM
Yeah I did! My R/T only got better after that.
My friend was in his 00 Z28, his best run of the night was a 12.7, on this pass he actually went sideways, poor M6.
Badazz 97 TA Oct 24, 2009 08:17 AM
hey i was damn close! good job. seems about right with what you have done
AChotrod Oct 24, 2009 11:44 AM
congrats!! Car runs good for the MPH.
© 2026 MH Sub I, LLC dba Internet Brands
