10k to spend on an engine
Old Nov 25, 2009 | 11:33 AM
86formula's Avatar
Originally Posted by Ray@Nitrous Outlet
no risk of blowing the engine on a stock PCM...I have a plan in the works to use the OEM PCM and opti, but turn the engine 8K plus.
now back to the original request it will be a little more difficult to do on a 8K budget if your are set on using the FAST XFI....doubt it can be a "good" solid roller on that $$$.
id be interested to hear how your going to do that.
lets assume that i have the FAST XFI
Old Nov 25, 2009 | 01:32 PM
Jazz-LT1's Avatar
I am a big fan of the LT1, but if I had $10,000 I'd be dropping in an LS3 which would run about $7000 new from GM performance parts. The other $3000 should cover the install.
Old Nov 25, 2009 | 01:52 PM
NemeSS's Avatar
10k will build a killer iron 6.0 based ls motor and will cover the swap install with a tubular kmember. and may get away with other parts in there too. if shop wisely.
Old Nov 25, 2009 | 02:23 PM
86formula's Avatar
that thought has crossed my mind since i have a 48k mile LS1 in my driveway that hit a deer
Old Nov 25, 2009 | 02:58 PM
Jazz-LT1's Avatar
Glad I didn't get beat up for suggesting that. I just built an LT1 myself but I only spent about $4000 total
Old Nov 25, 2009 | 09:57 PM
86formula's Avatar
i think im going with a forged 383, ill keep my LE2 heads with all of their hardware (only 5k miles) single plane ported and converted, FAST XFI and a carbed plate kit. im running 11.5 now so i think even just a cam bigger then a 226/230 and a dyno tune (mail order right now) could get me in the 10s.
Old Nov 25, 2009 | 10:09 PM
FASTFATBOY's Avatar
I will sell you my entire setup for 10k, all the way to the ecm, harness and headers. I will freshen it up before you get it.
Old Nov 25, 2009 | 10:20 PM
86formula's Avatar
PM me the details on your motor please, top to bottom
Old Nov 25, 2009 | 10:27 PM
kmracer's Avatar
theres a saying, its called keep it simple it simple stupid. K.I.S.S.
also remember RPM'S = ruins peoples motors...
i suggest you do just that, build an engine so that you can keep the stock crank, and do a BUDGET build. just do a simple 355, a beefy top end (23*, again, your goal is 10's on motor. EASY), do a single plane, and focus on lightening the car, the fuel system, build it strong and SAFE. that doest mean spend a grand on a crank and another grand on rods...
the parts you're talking about are for a mid 9 high 8 car.
Old Nov 25, 2009 | 10:29 PM
kmracer's Avatar
why are you so set on XFI?
Old Nov 25, 2009 | 10:31 PM
86formula's Avatar
forged 383, FAST XFI, Single plane, bigger cam, same heads isnt simple? if i do a build im not reusing the stock crank and would like to be able to put TFS 21* heads on it sometime in the future without doing a whole build again. car weighs about 3100lbs with me in it, has a Racetronix FP with hotwire kit, full rod end suspension front and rear with a 12bolt with 4.30s in it
  #32
86formula's Avatar
dont want the limitations of the stock PCM and it will be set up to switch from nitrous to N/A tunes on a laptop in the car
Old Nov 25, 2009 | 10:33 PM
  #33
kmracer's Avatar
you could easily spend 5k and meet the same goal.
Old Nov 25, 2009 | 10:35 PM
  #34
kmracer's Avatar
yea, but that can be acheaved using much simpler and cheaper methods..
msd 6al-2, same result.
Old Nov 25, 2009 | 10:49 PM
  #35
86formula's Avatar
this will be set up for when i can afford my TFS 21* heads
Old Nov 26, 2009 | 12:44 AM
  #36
SPEED#1's Avatar
Is this going in your little rx-7
Old Nov 26, 2009 | 12:47 AM
  #37
86formula's Avatar
RX7? no its going in my 96 camaro
Old Nov 26, 2009 | 02:48 AM
  #38
kmracer's Avatar
yea, thats understandable, but you dont really need to change the fuel tune when you're spraying, and the 6AL-2 can take care of the timing, the timing curve it totally tunable on a laptop. i just see spending 2 grand on engine management as a little bit of a waste. theres alot you can do with an XFI setup, but do you really NEED it?
Old Nov 26, 2009 | 06:57 AM
  #39
86formula's Avatar
completely forgot that i could adjust timing with it, im glad you decided to post up, im pretty sure ill be able to go single plane and do my nitrous set up within my budget now. what happens with an LT1 if it is spun above 7100?
Old Nov 26, 2009 | 07:04 AM
  #40
FASTFATBOY's Avatar
It hits a wall like a rev limiter.
You dont need to go above 7100, cam and gear it accordingly to stay under 7000.
You have a PM.
