Macs Mids to LT's What would i gain ? i searched and saw afew good threads from afew years ago. i want to squeeze as much out of my setup as possible. would the gains be noticed on a setup like mine (specs in sig) or even worth while ? options/insight would be appreciated thanks |
The MAC mids are arguably the best designed mid-tube header. Upgrading to long tubes will net you maybe a handful of HP, but it won't be substantial. I upgraded my MACs to Jet Hots. IMO, go with the long tubes and have done with it. |
maybe 5-10hp at the peak. |
id personally just do duals off the mids then swap them out for LTs |
i was thinking about going with ebay headers, everyone says there good. the only trouble is i dont want to lose room to my spark plugs. i was also thinking about upgrading it to true duel from my 3" catback. i want to try to get everything i possibly can out of my setup. its fast... just not fast enough lol |
Originally Posted by SoxXpupPeT
(Post 12598529)
The mid tubes and the LT's will have nearly the same peak power. LT's usually a 5-10 points more. However at lower and mid RPM's, the mid-tubes do not make nearly the amount of power that LT's do. The LT's have much better savaging down low and the gains are not just a handful, they are tremendous. Here is a graph of before and after. I was running AS&M mid-tubes and switched to LT's: http://i140.photobucket.com/albums/r...midtubes-1.jpg Look at the differences under the curve. When I put the LT's on, it had so much more low and mid power you would swear there were 2 more cylinders in the motor. So the answer is yes. There are huge gains when switching from mid-tubes to LT's when you factor in the big picture. The proof is in the graph. IMHO, the only reason to have mid-tubes is if you need to be emissions complient. Or if you are lowered. |
Originally Posted by wrd1972
(Post 12599982)
The proof is in the graph. |
Originally Posted by SS RRR
(Post 12600045)
What happened at 6000rpm? |
awesome information wrd1972! i now have something to look foward on doing after tires and brakes get freshened up :) maybe true duel 3"? :D |
(Post 12600045)
What happened at 6000rpm? For full disclosure, there was a spring change (now that I remember) in addition to the header change being represented in the graph. I installed Patriot extremes and that 100% cured the float problem and extended the very upper power to 6.5K or so. I would not expect the spring change to show any difference on the graph from 6K down. But you can see, the header difference represented is striking. |
Flawed info. |
"Flawed info." Yep, the problem is the valves could have been doing a dance and not seating properly until they really went South. |
Yes it is possible. But I have never heard of anyone really having valve control issues under 6K RPM. |
I swapped my MACs for Hooker LTs a few years back, it was a huge SOTP difference at the top end. At the time, I had a 350 with LE2 heads and an LE1HL cam. I did the swap after driving in a friend's TA with similar mods + LTs. |
The sound alone will make you happy u went LT'S. |
Originally Posted by RamAir95TA
(Post 12598540)
Originally Posted by irocurpony8489
(Post 12603122)
what mids are better mac or rksport? |
(Post 12602662)
But I have never heard of anyone really having valve control issues under 6K RPM. http://cranecams.com/?show=newsLetters&no=239 |
(Post 12602662)
Yes it is possible. But I have never heard of anyone really having valve control issues under 6K RPM. his car also was swapped over from mid lenght to long tubes years ago with back to back dynos and picked up 2 hp and 2-3 trq. |
| All times are GMT -5. The time now is 09:47 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
