piston questions
Also is there a certain compression distance have to use or is it based on it the deck needs work?
I will be building a .030 over 355 with a 6.0" rod looking for about 11.5 cr. going to probably end up with le2 setup so it will use 54cc heads. Also if the deck doesn't have to be messed with and using the setup mentioned, with a stock style thickness headgasket what cc piston would i need for that cr?
Deck height- 9.025
Bore - 4.03
Stroke- 3.48
Rod length- 6.0
Chamber volume- 54cc
Gasket Thickness- .04 (used this as just a general size)
Piston Dome- +4.0cc
Pin Height- 1.245 (this would be compression distance right?)
Which gave me:
Deck Clearance- 0.04
Compression Ratio- 11.91:1
Engine size- 355.1
Rod Ratio- 1.72:
Max Rod angle- 16.86deg
So this wouldn't be a problem unless the deck had to be milled down for some reason right? If i wanted a little less cr i could use a thicker gasket?
