Can't stop the engine from turning over... ... when bolting/unbolting flywheel/flexplate and pressure plate? http://i759.photobucket.com/albums/x...ntheground.jpg When unbolting just move 1/4" extension to other side of pan. |
Yeah you're going to have to get creative. I used a breaker bar between the pulley and against the sway bar (when I had it). |
Go buy a flywheel tool. It's a prybar with an arm that sticks out to the side that has a 90 degree bend at the tip. It engages the ring gear teeth at two points so you can hold it still. |
if you have some airtools it would come in handy |
To unbolt, absolutely. To bolt up though I'd rather stay as close to the torque specs as possible. |
I just had someone hold the front with a breaker bar (wedged in the balancer) and I torqued everything to spec just fine. Just make sure they're not whimpy :P |
| All times are GMT -5. The time now is 07:40 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
