Optispark Replacement Question
Old May 21, 2010 | 04:31 PM
madball's Avatar
Default Optispark Replacement Question
I am installing the optispark this weekend on my 96' WS6. Its is a Delphi unit that I purchased from thepartspros (formerly thepartladi). Question is should I take it apart and loctite the screws and the seal the cap to the base with RTV??? I have searched and most people say this is not necessary with the OEM opti's and that the loctite can actually weaken the plastic on the rotor and the RTV can put the contacts tolerance between rotor and cap futher apart. What do you all think think???
Old May 21, 2010 | 04:32 PM
RamAir95TA's Avatar
I've always installed them as they come in the box...some people swear by taking them all apart. I don't.
Old May 21, 2010 | 04:50 PM
ss.slp.ls1's Avatar
I swear by adding a dab of thread locker to the rotor screws. It can't hurt and I don't see how it could make the rotor weaker. Use moderation when applying it and be careful not to over-tighten the screws. I've replaced countless units for customers (AC Delco, Delphi, MSD, crappy aftermarkets) because the rotor screws backed out and detached from the base. Some add silicone around the base for better waterproofing. I've never had an issue with that.
Old May 21, 2010 | 09:16 PM
fex77k's Avatar
At least locktite the rotor screws, and running a bead of silicone around the case seal won't hurt a thing. If your spending the money replacing a opti you don't want to be back doing the same thing in 300 miles cause 2 pos screws came out(ask me how I know).
Old Jun 21, 2010 | 11:00 PM
xdanny510x's Avatar
when u guys say silicone the case thats the ouside of the case correct? around the edges? or is there pix of how they show where to put the silicone?
Old Jun 22, 2010 | 11:02 AM
ss.slp.ls1's Avatar
When you pull the cap off, you should see a little rubber ring that goes where the cap seals to the base. Just add a little bead of silicone all the way around where this rubber seal is.
Old Jun 22, 2010 | 05:57 PM
xdanny510x's Avatar
How bout as far as threadlock on the rotor screw and mounting screws and water pump ? Red or blue threadlock
Old Jun 22, 2010 | 06:10 PM
ss.slp.ls1's Avatar
I used a dab of red thread locker on the opti rotor screws. I use blue thread locker on the water pump bolts.
Old Jun 22, 2010 | 06:16 PM
xdanny510x's Avatar
Ight koo thanks u been a big *** help!
Old Jun 23, 2010 | 01:08 AM
BALLSS's Avatar
"red" on rotor screws
"thread sealer"...NOT blue or red lockTite on WP bolts that go into water jacket.
Old Jun 23, 2010 | 08:16 AM
Badazz 97 TA's Avatar
Why would you use blue thread locker on waterpump bolts? Are you retarded?
thread sealant is what you need Einstein.
Old Jun 23, 2010 | 09:30 AM
defaultexistence's Avatar
i had rotor screws back out because it was installed out of the box,make sure to get some of that silicone/rtv around the harness plug socket/cap area. imo
Old Jun 23, 2010 | 10:43 AM
ss.slp.ls1's Avatar
I've installed countless number of WP's and never once had a leak.
