Meziere HD water pump install issues
I purchased the HD kit and got it all in and the pump did not come with a gasket. so i figured it didn't need it and installed it, now it's pouring everywhere. Anyone know if this thing is supposed to come with a gasket of some sort or do i need to use a silicone type of sealer? It threw me for a loop because the mating surface of the pump is flat. Any help is apreciated!
Thanks
Sean
Thanks
Sean
Yup you reuse your origional one. It's always a good idea to alway coat your O rings with grease or oil. If you have thrown away your old tappered sealing ring just use rtv and itll seal fine.
