Autolite 104's Hey guys, I had a miss in the car and I was not sure what was causing it so I went a head and pulled the plugs out to see how they looked. I went ahead and swapped them with new plugs since they were cheap but I have some questions. The engine is a 383 with LE2 heads and LE custom cam. When I got the heads from Lloyd he said to use autolite 104's in it. I just pulled them out and I am not sure if I had a bad plug or what. On #7 cylider the plug was brown but all other cyliders were nice and clean. #7 was dry (No Oil) but brown. I checked my wires and they are look good. After changing the plugs I went for a run again and the miss cleared up but it feels like I may be weak on spark. I still need to check my TPS voltage but the car ran good for it being 94 degrees out but it did feel like it was laboring a tad. That may just be the TPS not being right on it but I will fix that this afternoon. I can post a pick of the plugs if need be but what do you all think about the auotlite 104 plugs and about what might be causing the one plug to be brown? I have a summit Opti on the car that was new with the build, and ignition modual and coil are 100k miles stock. Should I be running an MSD or look at changing the coil and ignition modual? Give me some thoughts as to wich way I should go. Also I have no CEL on but also I don't have a scanner and it has not been scanned so I have no idea if there are any codes. |
Those are good plugs. They are not your problem. Maybe that cylinder is a tad richer than the rest. Doesn't mean oil contamination. 104s are all I ever used in my 383". |
I ran 104's in my car and I like them over all of the other plugs I have ran. I have used them when I was fuelinjected and running ported stockheads and comp cc305 cam. I also used autolites in my nitromethane powered KX125 and my nitro banshee, both drag bike arm ripping maniacs. |
I Love AL's (copper cores AL103) long story short, broke down in OK after hours on a sat, ran this plug home, and it wasnt missing - dont ask me how... http://public.bay.livefilestore.com/...795.JPG?psid=1 http://public.bay.livefilestore.com/...797.JPG?psid=1 most AZ/Pepboys will scan the car for free.... Might want to call around and see if you can get the DTC |
| All times are GMT -5. The time now is 12:37 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
