Help pushin a stockbottom end lt1 into the 10s
#101
LS1Tech Sponsor
I just read through this entire thread, congratulations on hitting the 10's with it!
Several questions, do you have lower control arm relocation brackets on that 12 bolt?
Are you still running the factory torque arm? if you are, I'll bet it is flexing quite a bit at the starting line and allowing the rear to rotate. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
#103
LS1Tech Sponsor
The stock torque arm will start to bend about six inches ahead of the rear, sometimes for good. I had a guy back at the old EPP shop limp his Camaro in with the factory torque arm (on his Moser 12 bolt) bent so bad the rear springs almost fell out of their pockets. You might try borrowing someones aftermarket torque arm to see if it helps your 60ft times. Bob
__________________
#104
I have heard good things about the bottom hole as well for traction. I'm pretty surprised that you did that on the stock arm though, but I thought of more weight to be rid of. You could take out the window regulators and just put something in there to hold the window up.
#110
The fender metal is useless. The area of the fender where the metal is, is stiff as hell. You can get 7lbs off each side with a sawsall. You can get an additional 1lb each side if you trim it up a little better with a cutoff wheel.
#111
This past weekend I got a call from a friend that the camaro vs mustang street car shootout was going on so I loaded up the car and raced up at Esta Saturday AM. It was sweltering hot (i got a wicked neck sunburn) and they would only let us run eighth mile due to poor track conditions (water) but I still managed a 7.17 best so only down two tenths from last year with the heat and the cage
#117
Let me see if I can link it from my facebook
http://m.facebook.com/l.php?u=http%3...047632527&cb=5
Does that work? I posted it from my phone.
http://m.facebook.com/l.php?u=http%3...703826818&cb=5
#120
Video works for me.....but I'm surprised because I'm usually the one who can't see half the pics and vids on here. LOL I would have added you on FB, but I couldn't figure out how to get to your page or anything. It just brought up a big blank page with your video right in the middle.
