car runs for
Old 07-17-2010, 01:59 AM
z28camaro1996's Avatar
Default car runs for
about five mins and then will straight up die and not start till it cools down, if it does start it idles fine but wont take any gas. any suggestions?
Old 07-17-2010, 07:23 AM
joelster's Avatar
Hrmm....could be the ignition module on the driver side cylinder getting too hot and shutting down. Space it off of the head with some washers to see if that cures it.
Could also be the coolant temp sensor FOR THE PCM, which is in the bottom of the water pump. Make sure it's plugged in. That sensor tells the pcm what temp the motor is at. If it doesn't work the computer will still dump a lot of fuel into the motor, even after the motor warms up, because the pcm thinks it's cold. Car will richen out, and die, and won't start til it cools down. That is an easy one to spot if you can datalog the car.
Old 07-17-2010, 07:54 PM
that could explain why the car smelt gassy like raw gas.
Old 07-17-2010, 07:59 PM
red-_-z28's Avatar
it dies when it goes to open loop right..
Old 07-17-2010, 08:07 PM
it seems like it dies about a minute after warming up to 180. then it wont start it just desiels. and tries to start.
Quick Reply: car runs for
