PCV evacuation for boosted LT1's Wus up guys! Any help would be greatly appreciated! I have been doing some research on pcv evacuation for boosted cars but I have yet to see it done on a LT1. Some guys run one breather in each valve cover with a plastic tee that then routes down into the wastegate dump tube. Since the pcv valve is in the intake instead of the valve cover, do I use one breather coming off the intake where the pcv valve would be and the other from the pass. side valve cover or do I leave the pcv valve in the intake and drill a hole and install a breather on the drivers side valve cover. Thanx for any input. |
i just deleted my pcv, and put a breather in each valve cover, i put baffles in the valve covers so i wouldnt get oil in the filters. worked great so far, at 14 psi and 670 at the wheels thru a th400. |
What did you do about the pcv hole in the intake? |
pluged it, u can just weld up the pcv valve itself, or have the hole in the intake welded up. |
| All times are GMT -5. The time now is 11:02 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
