Any LT1 guys running Torco gear oils?
How's it goin everybody? I picked up my WS6 a few weeks ago, and have been "gearing up" (no pun intended ) to do a major tuneup and full fluids flush. My car has 125k on the clock. I ran Torco RGO 85w/140 in my LS2 GTO, it worked flawlessly. Now those rears are wayy different from these 10 bolts, hell I even had to use Ford friction modifier instead of GM in it! When it comes to the rear on my car I'll be installing GM 4.10 gears/install kit, and a TA girdle. My question is, will I be safe running the 85w/140, or should I go to the 80w/90? Your opinions are appreciated, thanks!
-Terry
-Terry
LS1TECH Sponsor
I agree and Moser will tell you the same.
__________________
95 Pontiac Formula- Stock engine with ATI Procharger, Moser 12 bolt w/4:30 gears, Rossler trans, Neil Chance 4000 stall, M/T ET streets, 10.914@ 121.90mph, 1.452 60ft. GMHTP November 2010 Feature Car. Check it out at:
https://www.motortrend.com/features/...ebird-formula/
http://www.youtube.com/watch?v=abZ1z...ature=youtu.be
I appreciate the info guys. I've searched and seen what most of the 10 bolts are running on here, I didn't see much about Torco, guess I know why now! Thanks.
