Speedinc. fuel line mod. Simple swap? Looking into these fuel lines to clean up the engine bay but as I'm looking at the pic I notice that there is only 2 fuel lines but when I look in the engine bay there are 3. Is one line eliminated? Are 2 the return line and 1 goes to the fuel rails? What am I missing here? http://www.speedinc.com/cont.cfm?cid=C0001018 |
The third line is for evap you can delete it fairly easily. |
Originally Posted by OlMastaScrilla
(Post 13919736)
yep^^ Pretty simple job hardest part is deciding where to drill the holes. |
(Post 13919736)
Youll see it all when installing the kit. I just put a filter on the end of the evaps hard line under the car. |
ach could you take pictures of the fuel lien relocation done to your car and where ou had to drill at thanks |
Originally Posted by AChotrod
(Post 13919803)
if you take off the evap it will throw a code and the filter I used was just a small spector cone filter from autozone. Just popped it on the end of the hardline under the car. |
that looks very clean...what kinda of valve cover are the ones on your car really like them. |
nice i might add that to my to do list for winter mods |
(Post 13919736)
any gains with it? |
Rob94hawk-It goes through the inner fender well on the driver side, you can cut it off right in there (a black plastic piece holds in all the lines) and put a filter on it. Or do what i did and follow it all the way back to the tank and put the filter on back there. But trust me when you get the inner fender out it becomes very obvious. ThorsLT1- There are no proven power gains that i have ever heard of, it mearly burns off gases that build up inside the tank. |
Originally Posted by Rob94hawk
(Post 13925461)
Nice! I'm guessing I can get those grommets at any autopart store?
(Post 13925757)
Trying to google the crap out of that right now cause I'm not getting it. I'm sure once I see it I'll figure it out.
Originally Posted by ThorsLT1
(Post 13925773)
any gains with it? Matt |
© 2024 MH Sub I, LLC dba Internet Brands
