oil pressure gauge doesnt fit after headers so my oil pressure gauge doesnt fit after i put my lt's on, they get in the way of that big rubber piece? what do i do? |
What big rubber piece? If it can't be fixed, you can relocate it to the back of the intake manifold like the late 94+ cars. |
That big rubber piece is a heat shield for the sensor, you can slide it off and up the wires to get it out of the way, then slide it back on. |
I put a brass tube, with a 90* elbow on it, then put the sensor back on. Cost like $3 at Menards, and now the sensor points wires to the front of the car with no issues... |
I took that piece off. |
took what piece off? the heat shield? |
i relocated mine behind the intake manifold. |
is there a write up for relocating it, becuase that would probably be the best choice |
Originally Posted by Young Maro
(Post 14039670)
took what piece off? the heat shield? Had to replace the sender once only because I broke it installing my headers and wondered why my gauge was spiked lmao |
© 2024 MH Sub I, LLC dba Internet Brands
